Wide range regulator
34,459
How about using LM317HV regulators.
They have a maximum differential rating of 60V which is okay at a 15V output but is marginal under short-circuit conditions.
Also their nominal output current limit is 0.3A at a 45V differential so that could also be marginal.
To solve those problems you could use two LM317 HV in series, with the first one set for about a 35V output.
That solves the voltage problem and the current limit at that lower voltage is well above your desired 0.3A.
Note that the regulators need to be on a good heatsink as they have to dissipate 13.5W total under worst-case conditions.
karas
Joined Sep 8, 2011
211
I only need 4.5w ,vo=15.io=.3A, if the input voltage go up o 70v,how can i fix this problem, and can you please sketch your circuit
34,459
Edited to add current limit---
My proposed scheme won't work with a 70V supply so I changed it to use a N-MOSFET source-follower preregulator in front of an LM317 to reduce the LM317 input voltage below its maximum rating.
The 33V zener causes the MOSFET source follower output to be about 28V at the LM317 IN terminal (depending some on the Vth of the MOSFET you use), well below the maximum LM317 rating of 40V.
The N-MOSFET can be any ≥100V, MOSFET in a TO-220 or similar power MOSFET case so it can be mounted on a heat sink.
It must be able to carry at least 0.5A at 70V as shown in the safe-area graph in its data sheet.
The maximum dissipation at 70V input and a 15V, 0.3A output will be 14W for the MOSFET and 4W for the LM317 so they both must be mounted on an adequate heatsink.
The MOSFET's dissipation is 28W with the output shorted so,if you want to protect for a continuous short at the output you will need a heatsink that will dissipate 28W.
If you mount them both on the same heatsink you will need to use isolation washers for the LM317.
Q1 sets the current limit at slightly over 0.4A for an R4 value of 1.6Ω (I_Limit≈0.64/R4) .
The LTspice simulation of the circuit is shown below.
The voltages and output current are shown for a load resistance varying from 100.1Ω to 0.1Ω.
karas
Joined Sep 8, 2011
211
The 33V zener causes the MOSFET source follower output to be about 28V at the LM317 IN terminal, well below the maximum LM317 rating of 40V.
Thanks so much
thanks so much, can I get the LT spice for lm317
34,459
Attached are the files I use.
Put the .asy file in C:\Program Files (x86)\LTC\LTspiceIV\lib\sym\PowerProducts.
Put the .sub file in C:\Program Files (x86)\LTC\LTspiceIV\lib\sub
It should then show up in Power Products after closing and reopening LTspice.
karas
Joined Sep 8, 2011
211
Thanks so much, did you create this model for LM317?
dannyf
Joined Sep 13, 2015
2,197
google pre-regulators. they are essentially transistors whose regulation output floats with the output of the combined regulator.
walt jung made quite a few circuits of that nature and they are all fairly simple: the simplest can be done with a transistor, a resistor + a zener / led.
a pre-regulator, unlike the typically regulator, does not actually regulate (since it floats). All it does is to drop the excess voltage (and power dissipation).
34,459
google pre-regulators. they are essentially transistors whose regulation output floats with the output of the combined regulator............
The circuit I posted uses a fixed voltage pre-regulator which for a fixed output voltage as this has, would be the same as a floating preregulator.
