why
hiyan
Joined Sep 23, 2005
26
i wantto ask why we take Antenna length lemda/2 and lemda/4?
2nd in the end of antenna why resiatnace high?
3rd length of transmission line is depends on the wavelength of the signal being transmitted why?
4th how the standing waves are genrated in transmission line?
i hope all members who know guide me and explain me briefly.thanks
beenthere
Joined Apr 20, 2004
15,819
I think if you do some looking on the topic of resonance, most of your questions will be answered. All the things you mention have to resonate at the transmit/receive frequency in order to function efficiently. A little antenna theory will explain why quarter- and half-wave antennas work.
hiyan
Joined Sep 23, 2005
26
Originally posted by beenthere@Dec 7 2005, 10:24 PM
[post=12291]Quoted post[/post]​
i read but i did not found above questions answer so kindly tell me and explain me thanks.
n9xv
Joined Jan 18, 2005
329
"i wantto ask why we take Antenna length lemda/2 and lemda/4?"
Lamda/2 & Lamda/4 denote the physical half-wave & quarter-wave dimensions for the antenna in question. The quarter-wave antenna is the building block from which all antenna systems are designed.
The half-wave antenna is the fundamental design by which all antennas are ultimately compared.
"2nd in the end of antenna why resiatnace high?"
In a half-wave antenna, the current nodes are at minimum towards the ends of the antenna. Thus, minimum current = highest impedance.
"3rd length of transmission line is depends on the wavelength of the signal being transmitted why?"
This is due to velocity factor. In other words, the speed of electricity is slower through any "medium" than it is through a vacuum.
"4th how the standing waves are genrated in transmission line?"
Standing waves or standing wave ratio (SWR) is due to an impedance mismatch between feedline and antenna. Standing waves are the waves or energy reflected back towards the transmitter due to the mismatch. Standing waves are the "leftover" waves that did'nt get transmitted or radiated.
hiyan
Joined Sep 23, 2005
26
[post=12380]Quoted post[/post]​
Thank u all :)
