WHY WON'T MY 7 SEGMENT DISPLAYS COME ON?
Discussion in 'The Projects Forum' started by dyeraaron, Nov 10, 2008.
  1. dyeraaron
    Thread Starter Active Member
    Oct 27, 2008
    57
    AM I just retarded or I've just fried my brain on this thing? why won't my displays at least come on with just DC Power...I don't have an AC Frequency hooke dup just yet, but shouldn't they still come on?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    We know even less than you. Can you post up the schematic and the part number of the displays?
  3. mik3
    Feb 4, 2008
    4,846
    63
    I guess you forgot to connect the common cathode or common anode pin to ground or V+ respectively but a schematic will be helpful. Another reason is that you may use higher values of series resistors for each led segment than needed.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If they are LCD 7-segment displays, they won't work without the AC excitation.
