Why was my thread moved?
Discussion in 'Feedback and Suggestions' started by Aleph(0), Aug 12, 2016.
  1. Aleph(0)
    Mar 14, 2015
    356
    339
    So my question about unexpected ltspice simulator results was moved from _General Electronics Chat_ to _Programmer's Corner_ (Right Here) which I don't understand cuz Spice is abt circuit design not programming:confused:?
    Anyhow I'm not complaining or angry or like that it's just that I need to understand rhyme or reason of appropriate place for posts:confused:? Tnx:)!
    OBW0549 likes this.
  2. OBW0549
    Mar 2, 2015
    1,389
    932
    Wow. Just... WOW! :rolleyes:
    LTSpice (like all other Spice variants) is a CAD program used by electronic circuit designers to simulate the behavior of circuits. It is NOT used by programmers in the process of writing, testing or debugging programs.
    LTSpice is a hardware design tool, not a software design tool.
    Please move that thread back where it came from. It absolutely, positively DOES NOT belong in Programmer's Corner.
    cmartinez and Aleph(0) like this.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    I agree, Programmer's Corner seems a poor fit for what is mostly an analog simulation tool and the nature of your question. Would a question about defining a new device in Eagle also be included in Programmer's Corner? If not, then why should the definition of a device in LTSpice be considered programming?
    The problem may be that general chat includes an "all of the above" statement,
    What doesn't fit that description and is related to electronics?
    That is a little like the multiple choice question that includes "D: None of the above" and " E: All of the above" as distractors. It's hard to argue that E is not always the correct answer. Some test writers try to get around that paradox by adding, "Which one of the following is the best answer," but that doesn't really solve the problem. It is better just to rewrite the question.
    Maybe the description for what is to be included in general chat needs to be reconsidered? PS: I don't think adding "not included in other categories" is the best answer. ;)
    John
    Aleph(0) likes this.
  4. R!f@@
    Apr 2, 2009
    8,787
    771
    Mine also got moved. I know my thread does not belong there. But me got no response.
    So I moved on.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I think that view might be a bit too narrow. It is a textual description of a circuit. This circuit is rendered by a text to graphics compiler. The models and sub-circuits are also described by text files that are compiled by the simulation engine. Is the ultimate purpose of the program what distinguishes programming from non-programming? I think not. The original SPICE program's input and output looked more like programming and less like circuit design than you might suspect.
  6. OBW0549
    Mar 2, 2015
    1,389
    932
    Some further thoughts on what I wrote in #2 above:
    The subheading for the Programmer's Corner forum reads as follows: "Forum for software engineering and programming languages: C, C++, C#, Fortran, Java, Matlab, etc."
    So I ask myself, is LTSpice (or any other variant of Spice) used in software engineering? Obviously, no.
    Does LTSpice belong as a member of a list of programming languages akin to C, C++, C#, Fortran, Java, or Matlab? Again, obviously, no.
    LTSpice is a circuit design tool, not a programming language or software development tool.
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    I see that ScottWang moved it to the programmers corner.
    I moved it back to the general chat.
    Bertus
  8. OBW0549
    Mar 2, 2015
    1,389
    932
    Thank you.
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The number and type of programming languages is constantly changing, and to suggest that the abbreviated list of example languages given in the quote is exhaustive is intellectual jiggery-pokery. From a career spanning half a century in programming, software engineering, and circuit design I can tell you that you need a better argument to persuade me that SPICE is NOT a programming language. I actually think the "etc." covers my point adequately.
  10. jpanhalt
    Jan 18, 2008
    5,699
    909
    That argument would put EAGLE discussions there too, as well as almost any CAD program that can be driven from a command line. For example, here is a portion of the text file for a library device:
    width="0.1524" layer="21"/>
    <wire x1="17.78" y1="0.635" x2="17.78" y2="-0.635" width="0.1524" layer="21"/>
    <wire x1="17.78" y1="-0.635" x2="17.145" y2="-1.27" width="0.1524" layer="21"/>
    <wire x1="17.145" y1="-1.27" x2="15.875" y2="-1.27" width="0.1524" layer="21"/>
    <wire x1="15.875" y1="-1.27" x2="15.24" y2="-0.635" width="0.1524" layer="21"/>
    <wire x1="10.16" y1="0.635" x2="10.795" y2="1.27" width="0.1524" layer="21"/>
    <wire x1="12.065" y1="1.27" x2="12.7" y2="0.635" width="0.1524" layer="21"/>
    <wire x1="12.7" y1="0.635" x2="12.7" y2="-0.635"
    John
  11. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    I think that both PCB design and circuit design programs would fall under CAD (computer-aided design).
    Bertus
  12. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I would have absolutely no quarrel with that assertion. What constitutes software engineering is incredibly broad, and includes many languages and application areas. People who use languages to solve application problems are just as much software engineers as the guys who write the programs, compilers, and operating systems. Notice that Matlab is included in the list of "favored" languages for the Programmer's Corner, but it is hardly a language you would use to write an operating system.
  13. crutschow
    Mar 14, 2008
    13,478
    3,365
    My 1½ cents.
    Spice is definitely not a programming language, any more than Excel is.
    Of course software is what does the simulation, but that's as far as it goes.
    Questions on Spice certainly belong in the circuit design or CAD area and not the programming area.
    OBW0549 and Aleph(0) like this.
  14. Papabravo
    Feb 24, 2006
    10,340
    1,850
    That is quite simply an ignorant statement. SPICE has all the required elements in the formal definition of a programming language. It may also be a CAD system or many other things, but applying the duck test, it is also a programming language. It has syntax, it has semantics, and it implements a behavior.
  15. Aleph(0)
    Mar 14, 2015
    356
    339
    Papabravo tnx for feedback but I say sort order can be conscientiously rationalized any way around so the test has to be where ppl expect to find the subjects and I just can't see Spice questions expected in Programming forum:confused:? Anyway I know it can be hard call:cool:!
    Thanks Bertus! And thanks to everybody on thread for intelligent discussion of my concern:)!
    OBW0549 likes this.
  16. Aleph(0)
    Mar 14, 2015
    356
    339
    OBW0549, FWIW I say Spice is in category like Mathematica cuz even if it can be technically described as programming language it is only practical for narrow application which IMO makes it come more properly under sort order of _electronics design tool_ Just like Mathematica should be classed as _mathematics computation tool_ So I'm saying I totally agree with you:)!
    OBW0549 likes this.
  17. #12
    Nov 30, 2010
    16,665
    7,310
    Mr. Pragmatic says, "Put it in the Forum most likely to get attention from people conversant in the subject matter."
    Use the human factor for this one.;)
    Aleph(0) and OBW0549 like this.
  18. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I guess we can all agree that it just might be a breath mint and a candy mint.
    GopherT and Aleph(0) like this.
  19. Aleph(0)
    Mar 14, 2015
    356
    339
    I say it all depends on whether or not it really has retsyn whatever TF that is:D!
  20. #12
    Nov 30, 2010
    16,665
    7,310
    It's vegetable oil hiding under a magic word to mystify the consumers into bringing their money.
