Why Vds never goes to zero in ltspice simulation in this case? Boost PFC Converter
Discussion in 'The Projects Forum' started by AbhimanyuSingh, May 23, 2011.
  1. AbhimanyuSingh
    May 22, 2011
    24
    Why do Vds never goes to zero...even with a bjt, the same happens. The current through the mosfet follows its equation that depends upon (Vgs-Vth). But the current passing through inductor is very very high as comapred to the mosfet current. Is that the reason..??What should I do then? A boost pfc converter isnt supposed to be like this??
  2. CDRIVE
    Jul 1, 2008
    2,223
    99
    In the future just post the image of the schematic. Even those of us with LT Spice installed would rather just view the schematic, instead of downloading your spice.
  3. AbhimanyuSingh
    May 22, 2011
    24
    here is the image.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    You need to choose a MOSFET model. The generic NMOS in your schematic is a small geometry device, with very high Rds(on). Right-click on M1 and choose a part with low Rds(on).
  5. CDRIVE
    Jul 1, 2008
    2,223
    99
    Are you expecting Rds(on) to equal zero? Absolute zero isn't possible, with any model.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    I originally thought that this was his question, but if you run his sim, probing Vds makes it look as if the transistor is not switching. However, if you probe the drain current, it pulses at 1mA. If you change the model to IRF6635 (or some other BF MOSFET), the drain current pulses reach 190A. Obviously, this is excessive, but I think it illustrates my point.
  7. CDRIVE
    Jul 1, 2008
    2,223
    99
    Thanks Ron, that clears it up.;)
  8. AbhimanyuSingh
    May 22, 2011
    24
    Thanks Ron and Cdrive...thanks a lot...it works now.
