Ah-ha! then it is a logic level-shifter. 5v to 3v3@booboo
In your second picture, the output is high when input is low.
In the first picture, the output is high when the input is high.
I guess it could be but, 5V in to 3V out. But, as drawn and not knowing exactly what the rest of the circuit does, I would say thatAh-ha! then it is a logic level-shifter. 5v to 3v3
I never seem to have a need for bi-direction level shifter. One direction has always been enough. It is an interesting metal challenge but in practice, an output drives an input. The output rarely switches to become an input and input becomes an output to necessitate a bi-directional level shifter.Here is a link to a discussion of bi-directional level shifters: http://www.adafruit.com/datasheets/an97055.pdf (actual creator was Philips AN97055). This is a more practice-oriented example: https://learn.sparkfun.com/tutorials/bi-directional-logic-level-converter-hookup-guide
John
If SparkFun is the seller, then the application will likely be some older/cheap/through-hole device communicating with an RPi.How about in an I2C bus? Clearly, Philips and Sparkfun felt there was a need. And a bidirectional bus can be use one-way too.
John
