why transistor is used?
Discussion in 'General Electronics Chat' started by corefinder, Dec 24, 2012.
  1. corefinder
    Oct 6, 2011
    55
    Here in this figure i want to know what role Q3 and Q4 are playing. I could have directly connected Q1 and Q2 directly with the micro controller....
      File size:
      34 KB
      85
  2. Dodgydave
    Jun 22, 2012
    5,172
    778
    Q3/4 are drivers for the Pfets Q1/2
    SPQR likes this.
  3. corefinder
    Oct 6, 2011
    55
    Do fets always require drivers like this or when the fet needs higher gate voltage than microcontroller could provide
  4. corefinder
    Oct 6, 2011
    55
    Yes, if the collector current is zero then how Vgs will obtain the desired level
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    Your schematic does not have enough contrast. Everything is faint. I can barely see the details. I used to have a program to fix it but now the program is gone.
    It looks like the collectors of Q3 and Q4 have nothing to provide a positive voltage so they won't work then the Mosfets also won't turn off.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    I think what you are pointing out is the fact that the gates have no pull-up resistors. It won't work without them. The gates need to be pulled up to +BAT.
    You need drivers like this if the drain voltage is higher than the microcontroller's vcc (which it is in this case).
    What is the purpose of D1?
  7. crutschow
    Mar 14, 2008
    13,526
    3,393
    As noted, that circuit will not work as shown.
    The P-MOSFETS require a negative gate-source voltage to turn-on, which is provided when Q3 and Q4 turn on (source is at plus voltage and gate at ground). But the circuit has no pull-up to turn the MOSFETs off (zero volts Vgs) when Q3 and Q4 turn-off. Thus resistors R3 and R4 need to be between the respective MOSFET gate and source, not to Q3's and Q4's collector.
  8. corefinder
    Oct 6, 2011
    55
    D1 is schottky diode to prevent reverse flow of current
  9. corefinder
    Oct 6, 2011
    55
    I am not able to understand how Q3 and Q4 are working. Even there is base current but no collector current can flow. Collector terminal is connected to gate terminal of fet. so Vc is zero always. so this fet is not controlled by microcontroller.
    I give up this circuit :(
  10. Ron H
    Apr 14, 2005
    7,050
    657
    That's what we've been trying to tell you.
    You don't have to give up. Do it as in the attachment.
    What are the values of R3, R4, R5, and R6?
  11. ScottWang
    Aug 23, 2012
    4,936
    777
    If you have ACDSee software then you can use it to adjust the contrast of the schematic.
    1. Open schematic.png with ACDSee, move the mouse cursor to the schematic, press right button and choose Edit/Open in Editor.
    2. Choose the editor menu on levels, and click levels
    3. Press enlarge key until you can see the circuit clearly, and adjust gamma, press OK when you feel adjusting is ok.
    4. The last is press save on the menu, and press ok, then it's done.
    5. Exit the Editor.
    6. Reload the schematic.
  12. ScottWang
    Aug 23, 2012
    4,936
    777
    I just want to say that about the off resistor Rsg, but Ron H is more quickly, so I adjust contrast of the schematic that Ron H just posted.
    absf and Ron H like this.
  13. grahamed
    Member
    Jul 23, 2012
    99
    11
    I don't know why I am seeing this thread at this time, but .....
    I guess I am missing something but it looks like both FETs are switching a positive supply to a ground referenced load, yet they are not wired the same, supply to drain and out to source in one and vv in the other.
    I know that the FET channel will pass current in either direction when turned on, and won't when it's not but what about the body diode?
  14. wayneh
    Sep 9, 2010
    12,406
    3,256
    Why answer a four year old question, with more questions?!
  15. GopherT
    Nov 23, 2012
    6,340
    4,094
    it is always nice to see a thread where @Audioguru and @Ron H participated and - what the heck happened to Ron?
  16. ScottWang
    Aug 23, 2012
    4,936
    777
    I think he is ok, just getting older and want to take a rest.
    wayneh and GopherT like this.
