Why SRAM and DRAM do not use flip-flop?
Discussion in 'Homework Help' started by feli, Jul 8, 2011.
  1. feli
    Apr 24, 2011
    6
    Hi everybody,
    Could you please help me with the following things,
    A 4-bit register uses 4 flip-flops. (each flip-flop stores a bit).
    SRAM uses 6 transistors to store a bit, whereas DRAM uses 1 transistor and 1 capacitor to store a bit. My question is why SRAM and DRAM do not use flip-flop to store a bit?
    (I am sorry for my English, and I am not a native speaker, and also I am a newbie)
    Regards
    Feli
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    A flip flop needs much more components to be made. It needs approximately 14 flip flops, so it's a matter of economy.
    I 'll try to be more specific on the number and find a schematic too.
  3. joeyd999
    Jun 6, 2011
    2,757
    2,932
    Actually, an SRAM does use flip-flops constructed of 4 transistors. The other two are used for reading/writing data. If it didn't use flip-flops...it wouldn't be static.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    You could call it a flip flop, but the construction of a standard flip flop is much different than a 6t SRAM.
  5. joeyd999
    Jun 6, 2011
    2,757
    2,932
    Ahhh...but there are many ways a flip-flop can be constructed...relays, DTL, vacuum tubes, transistors...just because the circuit doesn't look like a typical flip-flop, doesn't mean it isn't one. To be technically precise, these should all be called "bistable multi-vibrators". The term "flip-flop", according to wikipedia, wasn't even well defined, historically:
    I submit for the jury that a SRAM cell is, indeed, a flip-flop.
  6. joeyd999
    Jun 6, 2011
    2,757
    2,932
    BTW, I can (and I have) build a practical SR flip-flop with two cmos inverters and two resistors.
  7. Georacer
    Nov 25, 2009
    5,151
    1,266
    Well, ok. It is a flip flop since it can have only two states. What I wanted to point is that it's not your classic 7474 flip flop.
