why resistor is open in this circuit
Discussion in 'The Projects Forum' started by Benengineer, Feb 23, 2016.
  1. Benengineer
    Feb 6, 2016
    101
    Hello, can anyone help me with resistor issue in this circuit
    Please see resistor R149, the value is about 1K. However, when I turn on the power, the resistor is open when I measure it with multi-meter. Does anyone know the reason?
    The other circuit for LINE, LINE_AFT_SHUNT and NEUTRAL is below.
    Thank you for your help.
  2. #12
    Nov 30, 2010
    16,703
    7,341
    You are not supposed to try to measure ohms with the power on.
    Turning the power on doesn't magically make the resistor turn into infinity ohms and turning the power off doesn't magically make the resistor 1K again.
  3. Benengineer
    Feb 6, 2016
    101
    Thank you. I mean its value is Mohms, not 1K when the power is off. I guess the esd damage the resistor. Am I right?
  4. #12
    Nov 30, 2010
    16,703
    7,341
    Resistors are mostly immune to electrostatic discharge, but if it measures as too much resistance with the power off, it's wrong. More likely is you have a mistake in something else.
  5. Dodgydave
    Jun 22, 2012
    5,154
    772
    Lift the resistor out at one end and then measure it, with the power off.
  6. Benengineer
    Feb 6, 2016
    101
    It is totally open now
  7. Dodgydave
    Jun 22, 2012
    5,154
    772
    So its open circuit, over 1meg ohms?
  8. mcgyvr
    Oct 15, 2009
    4,791
    976
    Then its destroyed.. or your meter can't measure it.. or its not the resistor you thought it was.. or you don't know how to use your meter properly..
    absf and #12 like this.
  9. Benengineer
    Feb 6, 2016
    101
    thank you, I am checking it now.
  10. Benengineer
    Feb 6, 2016
    101
    Yes.
  11. Dodgydave
    Jun 22, 2012
    5,154
    772
    Case closed....
  12. RichardO
    May 4, 2013
    1,341
    429
    It seems to me the next questions should be: "Why did the resistor fail?". I am guesing there is something wrong in the "LINE_AFT_SHUNT" circuit.
    edit:
    And the next question is: "What else has failed?"
    absf likes this.
  13. #12
    Nov 30, 2010
    16,703
    7,341
    It's hard to kill a 1K resistor unless you burn it to death. I'm with mcgyver in post #8. There simply has to be some other mistake going on.
  14. RichardO
    May 4, 2013
    1,341
    429
    Does the resistor look burned?
  15. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    My first ever DMM was provided by someone doing that.
    A Hung Chang obscure model that I rescued from the bin, the resistance and ACV ranges were dead.
    Nothing to lose I opened it up - a complex looking LSI chip and a socketed op-amp - take a wild guess at what I tried next.
    There was a preset pot on the board, so I borrowed a meter with a recent calibration certificate and made sure the restored ranges were at least somewhere close to where they should be.
  16. Benengineer
    Feb 6, 2016
    101
    The resistor is damage
  17. ian field
    Oct 27, 2012
    4,447
    791
    Could be anything downstream - recently I had a TV with breakdown in the common mode choke, that probably wouldn't have shown up on DC checks.
    Take out the chopper transistor(s) - if it still goes bang; its probably the bridge rectifier.
