why opamp clip @ 15V
Discussion in 'General Electronics Chat' started by romy, Jan 5, 2009.
Thread Status:
Not open for further replies.
  1. romy
    Nov 30, 2008
    12
    could any1 tell me why opamp clip @ 15v supply ...............?
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    Your question does not make sense.
    Maybe your opamp has a 15V supply?
    And when you overdrive its input then its output clips at 13.8V or at 15V?
    Which opamp?
    Then turn down the level of the input and its output won't go high enough to clip.
    What is the input? Audio?
    Is the opamp biased correctly? Post the schematic of your circuit.
  3. Papabravo
    Feb 24, 2006
    10,338
    1,850
    ...because you can't get something for nothing.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Attach a schematic and we can give you a better answer to your question.
    hgmjr
Thread Status:
