Why not stick multimeter across wall plug?
Discussion in 'General Electronics Chat' started by Yaşar Arabacı, Dec 2, 2014.
  1. Yaşar Arabacı
    Nov 11, 2014
    32
    A book I am reading warns me that I shouldn't stick a multimeter across a wall-plug to measure it's current. I am wondering why not? For example, if I have a multimeter that can measure up until 1kV and I am trying to measure 220V AC wall-plug, I would imagine that multimeter can handle it. Am I missing something here?
  2. Brevor
    Apr 9, 2011
    282
    56
    Voltage and current are 2 different things, Your wall plug is 220 VOLTS you can measure that with your multimeter set to volts. Dont try to measure current from a wall plug you will destroy your meter.
    Lundwall_Paul likes this.
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    you measure current in SERIES with a load. if you connect to a wall plug, it will be a dead shore (for a short time) in paralel with the 220 volts.
  4. R!f@@
    Apr 2, 2009
    8,787
    771
    You do that and you are lucky if you don't end up in the hospital or worse, in ur grave
  5. Brownout
    Jan 10, 2012
    2,375
    998
    Agree with Brevor in post #2. You should be able to measure volts with no problem. Use extreme caution! Make sure you're on AC Volts and set the range to higher than the voltage you expect to see. NEVER try to measure current across the outlet. The current function on your meter has ZERO resistance, and so you'll have 220V directly across a dead short. Your meter's death, and possibly yours, will be immediate and spectacular!
  6. mcgyvr
    Oct 15, 2009
    4,787
    974
  7. Gdrumm
    Distinguished Member
    Aug 29, 2008
    684
    36
    Tyrone does a great job explaining here:
  8. WBahn
    Mar 31, 2012
    18,085
    4,917
    The fact that it can measure a lot of camels (a thousand volts) is irrelevant when you are trying to measure goats (current).
    BR-549 likes this.
  9. wayneh
    Sep 9, 2010
    12,379
    3,234
    [responding to #1, not WBahn's goats]
    Why not? Many meters do not have a fuse the ammeter's high-current input, and so the meter itself becomes the fuse, just like sticking a pair of tweezers into the outlet (something I have direct experience with!).
    At best, there is a fuse in the meter that will protect you and your meter. Next up is the circuit breaker in your house for the outlet you are "testing"; it will likely trip at 15A if your meter hasn't already exploded. If the breaker fails to trip, it's a toss-up between the shunt inside your meter and your house wiring as to which will go poof first. I'd bet on the meter in your hand lighting up like a light bulb.
    Point is, your attempt to measure the amperage capacity of your outlet will result in destruction of the weakest link. You won't have time to see any useful measurement on your display.
  10. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    I would have thought if they went that far, they would have explained why?
    Max.
  11. MrChips
    Oct 2, 2009
    12,625
    3,451
    To measure AC mains current, do as Tyrone says. Get a clamp-on AC current meter.
  12. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    I have the type that plugs in to a regular meter.
    Max.
  13. snav
    Aug 1, 2011
    100
    10
    Mains supplied current should always be measured with non contact metering IMHO. When I first got my fluke 117 I discovered a DMM-11 was $32! More than the battery that I blew it on. You learn to check leads often when measuring DC current. I would use clamp accessory if it weren't that I spend most of my time in the MA range.
  14. Lundwall_Paul
    Oct 18, 2011
    222
    19
    When measuring current in series with a DMM you should be clear about the meters current range and have an idea what the load current should be. A red flag for reading current is series would be the gauge of the circuits wires. Like connecting a 10 amp DMM in series with a circuit 6 gauge wire. Clamp on meters are a very good choice.
  15. MrChips
    Oct 2, 2009
    12,625
    3,451
    No electrician measures AC mains current by connecting an AC ammeter in series with the circuit.
    There are two simple reasons to use a clamp-on meter:
    1. convenience
    2. safety
    Always use a clamp-on meter.
    strantor and Lundwall_Paul like this.
  16. ian field
    Oct 27, 2012
    4,447
    791
    IME; the fuse in a multimeter serves only one putpose - as an indicator that tells you the meter is Napoleon blownaparte.
    studiot and MrChips like this.
