Don't know why I _{c} collector current is zero. I have got these reading in ammeter and voltmeter.
Are you sure the two grounds symbols represent the same node? Sometimes symbols for global node connections let you specify a different global node in order to support multiple supplies and multiple grounds. But, usually, the ground symbol shown like that one will default to node 0, which is the simulator's reference node (for most, if not all, SPICE-based simulators).Don't know why I _{c} collector current is zero. I have got these reading in ammeter and voltmeter.
by Jake Hertz
by Duane Benson
by Aaron Carman
by Jeff Child
