why new word reactance
Discussion in 'General Electronics Chat' started by raks_universe, May 3, 2009.
  1. raks_universe
    Thread Starter Active Member
    Mar 15, 2009
    67
    Inductors "oppose" the applied current flow(Lenz law),then why we are not calling it as a resistance of inductor,and instead why we use a new word "reactance" for denoting it . Is reactance and resistance are same.(please notify the difference)
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Resitance occurs in both DC and AC circuits. Reactance only occurs in AC circuits. It happens when voltage or current is a function of the time rate of change of the other.
    Code ( (Unknown Language)):
    1.
    2. v = L * (di/dt)
    3. i = C *(dv/dt)
    4.
    Reactance is always a function of frequency, resistance is not a function of frequency
    Google and Wiki are your friends -- use them!
    http://en.wikipedia.org/wiki/Electrical_reactance
  3. KL7AJ
    Nov 4, 2008
    2,043
    292
    Energy will be LOST in a resistance, but not in a reactance.
    I might add that there ARE frequency dependent resistances, such as skin effect, but they are minor except at high radio frequencies.
    Eric
  4. mbohuntr
    Apr 6, 2009
    413
    32
    I agree, A resistor value is constant through a great range of frequencies, while an inductor as well as a capacitors reactance(resistance) will vary with frequency making them useful in filters for music and commication. The value must be calculated separately before being considered with resistance.
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    KL&AJ makes an important distinction.
    Inductors and capacitors are able to store energy (in magnetic and electrostatic fields respectively) while resistors cannot store energy - they only dissipate energy as heat.
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Apologies KL7AJ for the unintended name change!
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Quite right and, at sufficiently high frequencies an inductor develops inter-winding capacitance and starts to look like a capacitor, while capacitors start to look like inductors. Plotting a Smith Chart on a network analyzer for an apparently "simple" component is a truly mind bending experience as the complex impedance loops around and around.
    But that is way beyond the original question
  8. raks_universe
    Mar 15, 2009
    67
    Did you mean the reactance as only a phase change against current?
    If so,did they cause any power dissipation(pure) or not?
