Why my stepper motor don't not rotate using 293 motor driver ic?
Discussion in 'General Electronics Chat' started by Shyamal805, Apr 10, 2012.
  1. Shyamal805
    Mar 20, 2012
    27
    I want to rotate stepper motor using 293 driver ic. But facing a problem that when i connect power supply +Vs as +9Volt and +Vss as +5Volt the my driver ic is heating rise.
    My question is this driver ic needed +12 Volt as +Vs?
    Can is use +Vs as a +9Volt? and how can i rotate my bipolar stepper motor?
  2. chrisw1990
    Oct 22, 2011
    543
    41
    whats a 293?? use full IC names please. or post with datasheet.
    can you also supply your schematic?
  3. Shyamal805
    Mar 20, 2012
    27
    I use L293D as a motor driver ic.
  4. chrisw1990
    Oct 22, 2011
    543
    41
    and your schematic?
    also, what motor are you using?
    remember, any information you can give, is useful!!
  5. praondevou
    Jul 9, 2011
    2,936
    489
    Page 3 of the datasheet. it should be between VSS and 36V.
    9V and 5V should be ok. What's the input signal voltage?
    As was said, we need a schematic,.
  6. shortbus
    Sep 30, 2009
    4,088
    1,670
    The l293 will not run a motor by itself( well maybe a very weak/small one) it needs a l298 or similar h-bridge to run a bipolar motor
