why it dose not work (timer0 in 18f452)
Discussion in 'Embedded Systems and Microcontrollers' started by mhghost, May 16, 2013.
  1. mhghost
    May 16, 2013
    6
    hi i am a beginner with micro so i wanted to try to build a clock and here is the code
    Code ( (Unknown Language)):
    1.
    2. sbit LCD_RS at RB4_bit;
    3. sbit LCD_EN at RB5_bit;
    4. sbit LCD_D4 at RB0_bit;
    5. sbit LCD_D5 at RB1_bit;
    6. sbit LCD_D6 at RB2_bit;
    7. sbit LCD_D7 at RB3_bit;
    8.
    9. sbit LCD_RS_Direction at TRISB4_bit;
    10. sbit LCD_EN_Direction at TRISB5_bit;
    11. sbit LCD_D4_Direction at TRISB0_bit;
    12. sbit LCD_D5_Direction at TRISB1_bit;
    13. sbit LCD_D6_Direction at TRISB2_bit;
    14. sbit LCD_D7_Direction at TRISB3_bit;
    15.
    16.   char txt2[10];
    17.   char txt1[10];
    18.   int  x=0;
    19.   int y=0;
    20.    void main(){lcd_cmd( _LCD_CURSOR_OFF);
    21.    TRISB =0;
    22.    T0CON =0b10001111;
    23.     Lcd_Init();
    24.     while(tmr0h < 0b000011111){}
    25.     while(tmr0l < 0b01000011){}
    26.     x++;
    27.     T0CON =0b00001111;
    28.     tmr0h=0;
    29.     tmr0l=0;
    30.   if(x==60){x=0;y++;}
    31.   lcd_out (1,1,"time is ");
    32.   inttostr(x,txt1);
    33.   inttostr(y,txt2);
    34.   ltrim(txt1);
    35.   ltrim(txt2);
    36.   lcd_out(2,1,"m=");
    37.   lcd_out_cp(txt2);
    38.   lcd_out(2,9,"s=");
    39.   lcd_out_cp(txt1);
    40.
    41.
    42. }
    43.
    i don't know what is wrong but every time i come near a timer i mess up could some one please help me i am using a 18f452 pic and a 4 MHz cristeal
  2. mhghost
    May 16, 2013
    6
    can any one help me please
  3. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Hi mhghost, I saw your other thread too. :)
    I think the very first thing you need to do is work out HOW to get exact seconds, and make sure that works.
    Personally I prefer the simplicity and tunability of a Bresenham type system, which can make perfect seconds from any xtal speed.
    This page has a lot of C examples;
    http://romanblack.com/one_sec.htm
    Here is one, to give actual seconds from a TMR0 and your 4MHz xtal;
    1.
    2.   // uses 1 variable; unsigned long bres
    3.   // gets here every TMR0 int (every 256 ticks)
    4.
    5.   bres += 256;         // add 256 ticks to bresenham total
    6.
    7.   if(bres >= 1000000)  // if reached 1 second!
    8.   {
    9.     bres -= 1000000;   // subtract 1 second, retain error
    10.     do_1sec_event();   // update clock, etc
    11.   }
    That code goes inside your TMR0 overflow interrupt, and TMR0 prescaler set to 1:1.
    For now I would concentrate on getting the interrupt and that code working, and just make it toggle a LED every second.
    Then you can compare that to a household clock, and if the flashing LED is keeping good time you can then add more code, to count seconds and minutes.
  4. mhghost
    May 16, 2013
    6
    thanks man
    i will try it
