Why is this simple circuit un-stable?
Discussion in 'Homework Help' started by EngIntoHW, Jun 28, 2011.
  1. EngIntoHW
    Apr 24, 2010
    128
    I don't understand why the following operating points are not stable:
    1.
    W=0
    X=1
    Y=0
    Z=0
    2.
    W=1
    X=0
    Y=1
    Z=1
    In both operating points, there is current flowing through R.
    Must there be no current in a stable operating point?
    Thanks.
  2. ErnieM
    Apr 24, 2011
    7,434
    1,625
    It's an astable multivibrator, it's supposed to be unstable.
    Look at state1: It may start there but C will charge thru R so Z rises to X.
    When Z rises to change W from a low to a high the real interesting things happen, can you see them?
    Hint 1: stop using 1 and 0 and use volts.
    Hint 2: Z may jump greater then the Vdd.
  3. EngIntoHW
    Apr 24, 2010
    128
    Got it,
    Thank a lot mate! :)
