Yes. Changing the duty cycle does NOT by definition change anything other than the duty cycle. It certainly does not have to change the frequency - that's how a pulse width modulator works, constant frequency, variable pulse width.View attachment 87431 Changing the duty cycle by definition changes the frequency, but modulating frequency does not neccesarily change the duty cycle. Am I missing something here?
Your circuit is a shortcut, and you've run into what is lost. Without all of the voltage dividers and diodes, it is a modern version of the classic multivibrator circuit that is almost 96 years old. It basically is two monostables in series, and does in fact change frequency when you change the duty cycle because you are changing only 1/2 of the circuit. If you increase one collector resistance while decreasing the other, the duty cycle will change but the frequency will not. It is going to be very difficult to do compared to a standard PWM circuit that separates the frequency function from the modulation function.
ak
