Why is the resonance frequency of RLC with OpAmp not the same as without OpAmp?
Discussion in 'General Electronics Chat' started by Matjelo Naleli, Nov 9, 2015.
  1. Matjelo Naleli
    Oct 7, 2015
    39
    I have LTSpice simulation of RLC plus OpAmp circuit as shown in the diagram. I was aiming to build a transfer function (voltage to voltage) of the following kind:
    G(s) = -1/(L*C*s^2 + R*C*s + 1)
    with resonance frequency at
    f= 1/(2*pi*(L*C)^(1/2)) = 1/(2*pi*(7.5uH*15pF)^(1/2)) = 15MHz
    However I get resonance at around 20MHz.
    What could be the problem with my implementation which leads to 20MHz instead of 15MHz?
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    You must increase the op amp GBP. But nevertheless the circuit will not work in real life.
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    Look at opamp.sub.
    See how the generic opamp is modeled
    Here is how to model the "theoretical" circuit, where the opamp is really ideal. I also had to provide "bias" to the "opamp"....
    Matjelo Naleli likes this.
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The about 20 Mhz is as the two capacitors in series are seen.
    Then you have a total capacity of 7.5 pF, this results in a frequency of 21.22 Mhz.
    This happens because the input impedance of the opamp in infinite and the output impedance is 0.
    Bertus
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    With an ideal opamp, there is a virtual ground between the two capacitors. The current that flows through the series RLC to the left of the virtual gnd also flows in the feedback capacitor with a negative output, and the resonance is determined only by the by 15pF.
    Only if the opamp is non-ideal, and the virtual gnd isn't, (e.g. too low GBP) would the resonance shift higher in frequency...
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    OK, I am wrong. Glad you corrected the matter.
    The frequency I found is like there are the two capacitors in series.
    Bertus
  7. Matjelo Naleli
    Oct 7, 2015
    39
    Oh great I didn't know that the two capacitors are can be taken to be in series given tha there is ground between them. I naively took the transfer function to be the ratio of the feedback capacitor impedance and the input series RLC impedance.
    Thanks bertus for pointing that out, I am not sure if I understand how they are in series but the resulting frequency seems to be indicative of the serial connection of the two capacitors.
    MikeML, the frequency response that you showed there is exactly what I was hoping to get. So does this mean the opamp that I used is not ideal while the dependent voltage source you used can be seen as an ideal opamp? Also is 1e5 the gain of the voltage dependent voltage source?
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
    You can see the shift in resonance as "gain" is varied. The four plots are with gains of 1, 10, 100, and 1e5...
  9. MikeML
    Oct 2, 2009
    5,451
    1,066
    If the opamp has more than an open-loop gain of ~100 at 20MHz, the two capacitors are not "in-series" for the purpose of determining the poles of the transfer function. Read post #5 again, and Bertus's response in #6.
    gain = 1e5 is typical for most real opamps. The voltage-controlled voltage source wired as I show it behaves like an ideal opamp with infinite input impedance, zero bias current, zero output impedance, and most importantly for your case, infinite gain-bandwidth product, but a specified open loop gain...
  10. Matjelo Naleli
    Oct 7, 2015
    39
    Whenever I work with RC networks plus opamps I get the resonance frequency where it's supposed to be. But with RC networks it's not easy to get 15MHz without using small resistors which overload the opamp. So I then decide to include inductors and that's when I get this frequency shift all the time. At some point I ended up thinking that the inductor is incompatible with opamps.
    But now I think Jony130 and MikeML have pointed out something that didn't cross my mind, that of GBP or non-idealness of the opamp.
    A follow up question:
    Can I use the dependent voltage source as an ideal op amp for demonstration purposes or there is something I need to tweak first to make it have infinite input impedence and zero output impedence like an ideal opamp?
    Thanks for your contributions guys, it's really productive.
  11. Matjelo Naleli
    Oct 7, 2015
    39
    Thank you very MikeML, you just made it all clear with your last comment.
