Why is the no load current so high on my DC DC converter?
Discussion in 'General Electronics Chat' started by eddie500, May 1, 2016.
  1. eddie500
    Nov 5, 2011
    21
    I bought this 12 volt 25 amp DC DC converter, which has a input current range of 36 - 75 volts. I plan to use this for a project.
    When using 73 volts input, I noticed the DC DC converter was getting super hot.
    I thought I had a possible short, but I hooked up my fluke and checked the amps. With "no load" it was pulling 90 mA at the 73v input.
    That is a whopping 6 watts of power with no load on the DC DC converter.
    I thought there was something wrong until I checked the specifications and found that it is rated to draw between 80 mA and 140 mA with a typical 110 mA draw.
    I was very suprised about this high draw and no load.
    Is this normal for DC DC converters? Should I have bought something else?
    Here is the data sheet below of what I bought with full specs.
    http://www.mouser.com/ds/2/632/DS_Q48SC12025-372467.pdf
  2. ElectronicMotor
    Member
    May 1, 2016
    53
    6
    Just off the cuff, as a technician, I don't think the inverter is faulty, since it is brand new. It is 91% efficient at 300 W, leaving 10% power lost. 10% of 300 W is 30W lost. 6 W isn't too bad in standby mode. I think your inverter is fine, but don't quote me on that.
    DickCappels likes this.
  3. KJ6EAD
    Apr 30, 2011
    1,426
    364
    The short answer: because you're supplying it with a high (least efficient) input voltage and you've done no thermal management.
  4. Sensacell
    Jun 19, 2012
    1,184
    277
    The design of DC-DC converters always requires some compromise- it's impossible to design one that is super-efficient across all possible loads and input voltages, so they optimize it for a reasonable load scenario.
    When it's unloaded, the efficiency is terrible, load it up and that 90 mA becomes insignificant.
  5. DickCappels
    Aug 21, 2008
    2,779
    674
    I am quoting you on that because I agree with your analysis :)
