Why is one inductor lead shorter than the other?
Discussion in 'General Electronics Chat' started by DickCappels, Sep 29, 2015.
  1. DickCappels
    Thread Starter Moderator
    Aug 21, 2008
    2,780
    674
    The drawing above is from the datasheet for a Bourns inductor that I am using. One lead being shorter than the other is a surprise since the inductor is not magnetically biased. I don't remember seeing a phase indicator on an un-biased inductor before. It occurred to me that perhaps paying attention to winding direction might be useful when considering crosstalk between closely spaced inductors.
    Any thoughts practical application of the phase indicator?
  2. ericgibbs
    Jan 29, 2010
    2,602
    396
  3. kubeek
    Sep 20, 2005
    4,691
    806
    Maybe simply because it is easier to first stick one leg in and then the other, than to try both at once?
    Roderick Young likes this.
  4. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    Not all in that series have the longer leg?
    Max.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    When placed in a PCB, the leads get clipped to equal length before wave soldering.
  6. Brevor
    Apr 9, 2011
    282
    56
    we used to produce a product that used inductors like the one you show. 2 were mounted facing each other (top to top) across a gap where a coin rolled past. One coil transmitted across the gap to the other coil. If someone wasn't paying attention and wired the transmit coil backwards the circuit wouldn't work.
    DickCappels and ericgibbs like this.
