I'm controlling a servo from a 5V Arduino (Pro Trinket). I'm supplying 5V to the entire system from a 3A bench supply. scope_0.jpg shows the supply output when the motor's idle. Scope_1.jpg shows the output when the motor is not quite stalled, at which point it's drawing about 800 mA. I have the current limited to 1.5A at the supply. Why is the voltage drooping so much, and why is the ripple so high? I would think a 3A supply should be able to handle this without breaking a sweat, but it's a Korad, not a Keysight, so maybe not. Other explanations/suggestions? Thanks for your help.
