why is my sound wave square? 555 timer rc circuit
Status
Not open for further replies.
alexkymberly
Joined Oct 17, 2016
7
hi,
i made an rc circuit with a 555 timer in order to reach a desired freq. of 440Hz. the freq. reached and duty cycle was 50%ish, but why was my soundwave square?
34,451
If you connect to the timing capacitor you will get a quasi-triangular wave.
If you RC low-pass filter that signal you will get close to a sinewave.
You can add a buffer op amp to isolate the timing circuit from the RC filter and/or increase the signal level from the filter if needed.
Status
