Why is LM7805 output 4.94 volt only instead of 5 volt?
Discussion in 'General Electronics Chat' started by dante_clericuzzio, Jun 12, 2016.
  1. dante_clericuzzio
    Mar 28, 2016
    69
    Hi i would like to ask opinion from any experience/experts here...I am testing the LM7805 that i just purchased and using 9.6 volt battery...based on the datasheet it should produce at least 5 volt or a little more like 5.2 volts..However the output i see is only 4.94 volt my questions is
    Is the LM7805 defect or am i missing something here?
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,379
    651
    Unless you're buying a screened part, tolerance is 5%.
  3. tracecom
    Apr 16, 2010
    3,879
    1,396
    Electronic components have a tolerance. The LM series of voltage regulators are not precise devices, and 4.94 V is within the guaranteed range. Check the datasheet for its exact tolerances. There are other regulators that are more precise and there are ways to add some components to fine tune the output of the LM7805; again, this is described in the datasheet.
    dante_clericuzzio likes this.
  4. dante_clericuzzio
    Mar 28, 2016
    69
    Thank you for all the feedback now i understand
  5. bushrat
    Member
    Nov 29, 2014
    97
    23
    4.94V is not bad for 7805.
    If you need precision, consider using LM317 (or LM338 if you need high cirrent)
  6. dl324
    Mar 30, 2015
    3,379
    651
    From a TI datasheet:
  7. tracecom
    Apr 16, 2010
    3,879
    1,396
    The Fairchild datasheet specifices +/- 4%. And for good regulation, you need a .33uF cap from the input to ground and a .1uF cap from the output to ground.
  8. Nykolas
    Member
    Aug 27, 2013
    92
    31
    And who said your meter is accurate? E
    atferrari likes this.
  9. ISB123
    May 21, 2014
    1,240
    531
    That meter has 0.5% accuracy.7805 is working fine since its within the 5% tolerance.
  10. dante_clericuzzio
    Mar 28, 2016
    69
    Thank you for the suggestion actually i am trying to find a circuit diagram that uses 9 volt to output 5 volt and 1.5 amp to 2 amp current. But i couldn't find any....do you have suggestion or this is not possible to use 9 volt battery?
  11. ISB123
    May 21, 2014
    1,240
    531
    9V battery wont live long enough with 1-2A current draw.
  12. tracecom
    Apr 16, 2010
    3,879
    1,396
    An ordinary 9V battery will be depleted very quickly with a 1.5 to 2 amp drain. What are you trying to power?
  13. dante_clericuzzio
    Mar 28, 2016
    69
    It's okay if it is doesn't live long enough - but if it is possible would you mind to share the circuit diagram how it can be done
  14. ISB123
    May 21, 2014
    1,240
    531
    LM7805 will require a heat sink if high currents are drawn.
  15. dante_clericuzzio
    Mar 28, 2016
    69
    Thank you very much ISB123 i will try this and see how it goes
  16. ISB123
    May 21, 2014
    1,240
    531
    Diode is not needed if you make sure to connect the battery correctly.
  17. dl324
    Mar 30, 2015
    3,379
    651
    Assuming alkaline battery chemistry, you'd be lucky to get 5 or 10 minutes before the regulator dropped out.
    RAYOVAC 9V Alkaline Battery:
  18. eetech00
    Jun 8, 2013
    682
    116
    LM7805 is only good for 1A max...
  19. ISB123
    May 21, 2014
    1,240
    531
    They can go above 1A with a beefy heat sink.
  20. bushrat
    Member
    Nov 29, 2014
    97
    23
    LM338 is your best choice, it has max 5A output. (provided you have sufficient source to power it up)
    LM317 only has 1.5 A and you need heatsink.
    7805 can only provide 1A and you need heatsink if you are going over 0.5A
    Driving 2A from 9V battery will last you for few minutes before voltage starts to drop.
    drdhdmd and dante_clericuzzio like this.
