why excessive current draw?
Discussion in 'The Projects Forum' started by Gadersd, Aug 17, 2013.
  1. Gadersd
    Dec 8, 2012
    98
    I just connected a 7.4 volt battery to a 50 ohm resister and connected it to my homemade speaker which is a coil of wire on top of a magnet. I noticed that it drawed current well beyond 148 ma. Why would a coil of wire on a magnet draw so much current?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Is the 50 Ohms resistor in series or parallel to the "speaker" coil?
    Can you post a schematic or a photo of the setup?
    Bertus
  3. Gadersd
    Dec 8, 2012
    98
    As you can see I used two 100 ohm resistors in parallel to get 50 ohms. The resistors are connected to the speaker in series.
  4. crutschow
    Mar 14, 2008
    13,479
    3,366
    Measure the resistance. It must be less than you think.
  5. wmodavis
    Oct 23, 2010
    737
    150
    Since I = V / R, since your proclaimed I was higher than expected could be one of three things:
    1. "V" is higher than 7.4 V
    2. "R" could be lower than the 50 Ohms
    3. "I" could have been guessed, measured or read improperly.
    I guess it could also be any combination of those three. Double check them all.
  6. Gadersd
    Dec 8, 2012
    98
    The problem is that I do not own a multimeter, so checking those things is almost impossible.
  7. Metalmann
    Dec 8, 2012
    700
    223
    You can buy a multimeter for less than $10,00 nowadays.
  8. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,507
    I thought it was mandatory on this site? :p
    Max.
    Metalmann likes this.
  9. Metalmann
    Dec 8, 2012
    700
    223
    I just noticed I used a comma instead of a period.:confused: Oh, well.;):D
  10. tubeguy
    Nov 3, 2012
    1,157
    197
    What, if any, parts do you have on hand ?
    Do you have a DC supply (Wall Wort) voltage regulator IC, op-amp, comparator IC ? etc...
  11. Gadersd
    Dec 8, 2012
    98
    I do have a 5v regulator.
  12. tubeguy
    Nov 3, 2012
    1,157
    197
    I've got a dumb question:
    How did you measure the current ???
  13. Gadersd
    Dec 8, 2012
    98
    I did not actually measure it. I thought the current was high because I saw sparks.
  14. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,507
    You just want to give the impression of being continental! :p
    Max.
  15. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,507
    How many? :eek:
    Max.
  16. tubeguy
    Nov 3, 2012
    1,157
    197
    What color were the sparks ?
    Sorry ;)
  17. absf
    Dec 29, 2010
    1,493
    374
    If you dont have a multi-meter, how did you know that the current is well over 148mA?
    [edit] sorry! I didn't read page 2....
  18. t_n_k
    Mar 6, 2009
    5,448
    783
    I want to vote this as the thread of the year.
    JoeJester and tubeguy like this.
  19. Metalmann
    Dec 8, 2012
    700
    223
    When I first started out, the sparks did tell a tale of alloys.:D
    Or, not.;)
  20. tubeguy
    Nov 3, 2012
    1,157
    197
    Hi Gadersd,
    Please don't be offended by a little good-natured ribbing.
    It would help if we new what the final goal of this project is.
    Do you possibly want to build an amplifier for the speaker, or something else ?
