You're not wrong, it's not permitted. However much I think it should be.I thought that \(\lim_{x \rightarrow 0}\frac{1}{x}=\infty\), not \(\frac10=\infty\), which I thought was not permitted as an operation.
Was I wrong?
You left out; "x/0 is always infinity"...
An argument for the latter seems to be that if you take x/x (x non-zero) the answer is always '1'. So one reasons that likewise, 0/0 should be '1'
But 0/x (with x non-zero) is always 0. So one alternatively (in relation to the previous statement) reasons that 0/0 should therefore be zero.
The result of 0/0 is therefore indeterminate.
Greater and lesser infinities is one of the best proofs that infinity can't exist (other than in conceptual math). ie; infinity can't ever be real.Bill_Marsden said:...
What is a greater and lesser infinity? Think of ∞, then think of ∞+1. The latter is greater than the first, even though they are both ∞.
Wow! I really didn't expect that from a math guy! Isn't infinity widely accepted as the reciprocal of zero? Please explain!BillO said:...
x/0, where x≠0 is undefined, not ∞
That's bunkum! If I have a real eggcarton and remove 12 real eggs from it I have a very real zero eggs in the carton. Zero is real, infinity is not (unless you can demonstrate inifity eggs in the eggcarton). Zero amps is also very real.magnet18 said:...
Just to point out, both infinity and zero are conceptual numbers that can't exist in the real world.
Not in real analysis. You simply cannot divide by 0. There are just to many problems that occur if this is allowed. There are literally thousands of examples in math texts and on the web that offer cases where some paradox arises if you allow division by 0. Feel free to look them up.Wow! I really didn't expect that from a math guy! Isn't infinity widely accepted as the reciprocal of zero? Please explain!
I understand your point, and I also understand that X*0=3 can never exist. This was similar to my introduction to the calculus concept of limits. There are situations where conventional mathematics breaks down. Since very few things man made (such as math) is perfect, I can live with it.Division comes about because one would like an inverse operation to multiplication. Thus, if x*b = a, then one might want to be able to solve equations where e.g. x represents an unknown and a and b represent given numbers. By dividing both sides of the equation by b, we get x = a/b.
Now, let's make it an equation with actual numbers: 4x = 3. OK, that means x = 3/4. Thus, 3/4 is the number that, when multiplied by 4, gives us 3.
Now let b = 0. We have x*0 = 3. Blindly following our solving method, we get x = 3/0. What is 3/0? It's not a number -- and mathematicians have declared this operation illegal because we are looking for a number x that, when multiplied by 0, gives 3. Now do you see the problem? Zero is defined in the axioms of a field so that the product is zero when it is multiplied by any number, including zero. Thus, there is no solution for x. Because of this problem, mathematicians simply declared division by zero to be undefined.
Thus, it is incorrect to write x/0 = ∞ because division by zero is undefined. That means you cannot do it within the rules of the arithmetic system you're working in.
Of course, anyone who has taken a calculus class learns about limits and limiting processes. This leads to the statements like "the limit of 1/x as x approaches infinity is zero". This is a completely different ball of wax, as it's often envisioned as a sequence of numbers that keep getting smaller and smaller. Still, it's one intuitive thing that leads to the common shorthand of x/0 = ∞.
Now, in the practical world, division by zero is supported in a python library I use a lot, numpy. And it's pretty convenient, as you wind up with a number that gets displayed as Inf or -Inf. You can also used it in subsequent calculations and it behaves as you expect. However, if you multiply Inf by zero, you get NaN, which means "not a number". But an expression like (number)/Inf will give you zero. This gives you calculational conveniences because it can mean that your complicated calculation won't stop after an hour if a division by zero occurs. But, at the same time, complete weirdness can propagate through your calculation when such things happen, so one needs to be cautious when allowing such things.
And perhaps why the answer / solution is deemed "indeterminate".You left out; "x/0 is always infinity"
And obviously non of those conflicting 3 pure math rules help you solve the problem.
Spoken like a true mathematician Bill. <wide grin> I ran into the same thing in college, and while I agree with you view all my electrical engineering profs disagreed, taking the limit at that point such that it equals one. I forget what proof it was required for.Not altogether true. x/sin(x) is undefined at x=0
Sure;
\(\stackrel{lim}{\small{x\rightarrow 0}}\ \ \ \frac{x}{sin(x)}\ =\ 1\)
But;
\(\frac{x}{sin(x)}\ \neq\ 1, \ \ \ \ where\ x\ = \0\)
Actually they are equal. Such are the ways or transfinite quantities. There are orders of infinities called the cardinality. The cardinality of natural numbers is less then the cardinality of the real numbers.What is a greater and lesser infinity? Think of ∞, then think of ∞+1. The latter is greater than the first, even though they are both ∞.
\(Taking\ the\ limit\ is\ fine,\ just\ don't\ substitute\ zero\ in\ there\ and\ say\ it\ works.Spoken like a true mathematician Bill. <wide grin> I ran into the same thing in college, and while I agree with you view all my electrical engineering profs disagreed, taking the limit at that point such that it equals one. I forget what proof it was required for.
0 is real and exists very often. I have 0 Ferrari's in my driveway.
If there are zero, then there is not a physical value, simply the absence of a value.That's bunkum! If I have a real eggcarton and remove 12 real eggs from it I have a very real zero eggs in the carton. Zero is real, infinity is not (unless you can demonstrate inifity eggs in the eggcarton). Zero amps is also very real.
by Aaron Carman
by Duane Benson
by Jake Hertz
by Jake Hertz
