Why don't I need resistors when using an/this LED driver chip?
Discussion in 'The Projects Forum' started by EnjoyIce, Apr 14, 2016.
  1. EnjoyIce
    Jan 13, 2014
    25
    Hi guys,
    I am using an LED driver chip to drive some LEDs ( https://www.adafruit.com/products/1429 ) and it says I do not need any current limiting resistors.
    Why is this actually the case? I have been using the chip and the LEDs are fine without resistors but was just wondering how it actually works (what the electronics are behind it!)
  2. OBW0549
    Mar 2, 2015
    1,389
    932
    You don't need LED series resistors because the TLC5947 driver IC handles the current limiting for you. The chip data sheet will probably shed some light on the details.
  3. dannyf
    Sep 13, 2015
    2,196
    417
    Because you don't have to have a resistor in there. A resistor is just a sample way to stablize the current.
    There happens to be other ways to stablize current and the chip is question is an example.
  4. TheButtonThief
    Feb 26, 2011
    219
    38
    When you think about it, a series resistor is just a very simple LED driver, a fixed one at that. What you have their still limits the current to each LED, just in a different way.
