why does voltmeter show voltage ?
Discussion in 'General Electronics Chat' started by ol'trusty, Nov 3, 2009.
  1. ol'trusty
    Sep 9, 2009
    48
    I am looking for an explanation on why does a voltmeter show voltage when on dc volt mode and I connect a capacitor ? Also when I touch both ends it shows between 100-300 millivolts (or put it on my tongue for example).
    Can someone please explain this..
    Trusty
  2. bountyhunter
    Sep 7, 2009
    2,498
    507
    Most modrn meters have an input impedance of 10 MEG ohms which means even a very small amount of noise picked up on the test leads will generate a voltage which it will display.
  3. ol'trusty
    Sep 9, 2009
    48
    How is my tongue noise ?
  4. hobbyist
    Distinguished Member
    Aug 10, 2008
    774
    65
    Because of the high input resistance as mentioned above,your getting phantom readings so no matter what you touch on your body with the probes a phantom reading will show a steady display the moment the probes are touched.
  5. davebee
    Oct 22, 2008
    539
    46
    The metal probes and your tongue may be forming a battery and chemically creating an actual voltage.
  6. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    touch some scope leads with your hands and see how much noise you are eminating.
  7. bountyhunter
    Sep 7, 2009
    2,498
    507
    The human body is a pretty good antenna for various RF signals.
  8. shortbus
    Sep 30, 2009
    4,096
    1,692
    Isn't the "noise" basically what a EKG or EEG measuring?
    Cary
  9. bountyhunter
    Sep 7, 2009
    2,498
    507
    No. An EKG measures a signal actually coming from your heart. The meter is measuring electrical junk on your skin picked up from the air.
  10. ELECTRONERD
    May 26, 2009
    1,146
    16
    A good experiment to prove this noise is to get an oscilloscope and touch the center conductor of the probe (don't touch ground!). You will get a oscillation on the scope which will be quite distorted, likely in the mV range.
    Austin
