If it is rated for 200ma continuous current, and my constant charging circuit below is set to only supply 80ma to my nimh battery? Makes no sense. I could understand if I was drawing near or above the maximum rated collector current. 80ma of power flows through the transistors collector and out the emitter. The LED's below have been replaced with my battery to be charged. 4k7 connects to + power rail at the top. I used 2n3904(collector current rating of 200ma). BTW>> I already know about the lm317t constant current setup. I need to know why this setup is running hot.
