why does the 3525 IC produce half frequncy?
Discussion in 'The Projects Forum' started by imbaine13, Jan 30, 2014.
  1. imbaine13
    Oct 6, 2013
    62
    Hello everyone,
    I know that the oscillator the 3532 IC feeds into a flip-flop, but can't seem to understand why when the oscillator is oscillating at 100Hz, the flip-flop out puts give 50Hz. May I get a simple explanation for this?
    Secondly, could someone help me with the --- dead - peak(+) - dead - peak(-) times of 50Hz and 60Hz modified sine waves which will give 230V RMS, when the peak voltage is 325V?
    Appreciate your time.
  2. shteii01
    Feb 19, 2010
    3,500
    511
    Vrms=Vpeak/(2^½)
    Vrms=325/1.414=229.8; round it up to 230 V.
  3. crutschow
    Mar 14, 2008
    13,478
    3,365
    A flip-flop triggers on one edge of the input waveform not both. Thus it changes stage on one (say rising) edge of input and then changes stage again on the next rising edge, giving an output frequency of 1/2 the input. This characteristic is used in typical counters to count down the input using multiple FFs connected in sequence.
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    the flip flop following the oscilator is to produce a 50 50 duty cycle in the output. the oscilator might not have a 50 50 duty cycle.
  5. crutschow
    Mar 14, 2008
    13,478
    3,365
    The only way the FF can generate a 50-50 duty-cycle is by halving the frequency. So you need an oscillator at twice the frequency that you desire at the FF output.
  6. alfacliff
    Dec 13, 2013
    2,449
    428
    thats what the origional question asked, "why does the 3525 ic produce half frequecy."
  7. Alec_t
    Sep 17, 2013
    5,968
    1,135
    A 50:50 duty cycle is important if, for example, you are using the output for push-pull drive of a transformer. Ratios other than that can lead to core saturation.
  8. crutschow
    Mar 14, 2008
    13,478
    3,365
    Was that question not answered? :confused:
  9. imbaine13
    Oct 6, 2013
    62
    Thanks, I know that, I just wanted to know the time spent in each of the states. In otherwords, for how long will the outout be dead (0v), then for how long it will be high(+325v), an then how long dead again and then low (-325) ... etc, for a period of 0.02seconds (50Hz AC). A modified sine wave.
    The intervals are such that the peak voltage is 325v and should give 230v RMS.
    Thanks for your input though.
  10. imbaine13
    Oct 6, 2013
    62
    Thanks for that. I with that logic, I would think that only one of the outputs gives half the frequency. If both outputs are used to drive say the power stage of an inverter, wouldn't the frequency get doubled taking us back to the original frequency? I'm a little confused?:confused:
  11. shteii01
    Feb 19, 2010
    3,500
    511
    Voltage=325 volts*sin(2*pi*50 Hz*time)
    So.
    Set Voltage=0 volts:
    0=325*sin(2*pi*50*t)
    You have one unknown, t, solve for it.
    And since it is sine, then you will have 0 volts at 0 seconds mark.
    Same for the others.
    Set Voltage=-325 volts:
    -325=325*sin(2*pi*50*t)
    you can actually make a leap here, -325 on the left must be equal to 325*(-1) on the right, so sin(2*pi*50*t) must be equal -1, you got one unknown, t, solve for it.
    Set Voltage=325 volts:
    325=325, sine must be a 1, so sin(2*pi*50*t)=1, one unknown, t, solve for t.
    Then you can do the same for 60 Hz.
  12. crutschow
    Mar 14, 2008
    13,478
    3,365
    Both outputs of the FF have the same frequency, just inverted (180° out-of-phase).
