Hello.
In regards to my previous question, I've been digging it and found some weird things to me.
Please see the pictures below.
You can clearly see that voltage over the load is depending on the load resistance (loading effect). I've learn that the output impedance of the negative -feedback Op Amp is a fraction of ohm so loading effect is negligible. However, the simulation shows different results to what text book says. Besides, the real circuit also shows similar tendency in amplitude. In real experiment, it is also observed that the pulse duration is extended about twice if the load resistance is above several hundreds ohms.
In simulation, I've replaced Op Amp to arbitrary ones and some of samples give similar results. I've not tested whole stock of Op Amp but It looks to me that high speed Op Amp has observable loading effect.
Could you give me some explanation of such a loading effect for Op Amp? Is almost zero output impedance for negative feedback Op Amp not universal? If so, how I can distinguish Op Amp which has such a effect?
Mod edit:
Please cut the useless part of the file and compress the file resolution to 800x600 or 1024x768.
Mod edit:
