Why does Microsoft make it so freaking hard to make a reinstall disk for Windows 10?
Discussion in 'Computing and Networks' started by spinnaker, Jan 8, 2016.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,074
    1,176
    I have been trying to figure out what to do to make a reinstall disk for Windows 10?
    What if you want to upgrade your hard drive or the hard drive goes bad and the OS needs to be reinstalled? Or the OS just gets totally hosed that it needs to be reinstalled?
    Best I could find is these instructions which don't make much sense to me.
    https://answers.microsoft.com/en-us...rom-your/07590098-90a9-4c7e-b6fe-5ce1632daf4b
    What on earth was MS thinking? You would think this would be a simple click to create a reinstall disk.
  2. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    I use Acronis S/W in order to make a clone copy, also It allows setting up multiple operation systems on the HD if needed.
    Max.
    #12 and nsaspook like this.
  3. spinnaker
    Oct 29, 2009
    5,074
    1,176
    Does it make a bootable DVD?
  4. spinnaker
    Oct 29, 2009
    5,074
    1,176
    And exactly what do I need?
  5. spinnaker
    Oct 29, 2009
    5,074
    1,176
    And it still should not be so freaking hard to make a reinstall disk.
  6. spinnaker
    Oct 29, 2009
    5,074
    1,176
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yes, and so does ImageX, and DISM.
  8. eetech00
    Jun 8, 2013
    679
    116
    It knows by checking the existing OS activation before the upgrade. It actually "marks" the disk drive to identify that it is upgradeable.
    Once it does this, it then displays the "upgrade to windows 10" flag on the task bar notifying you that the system qualifies for the upgrade.
    If you create a DVD using the media creator tool, the installation process will look for a qualified OS installation and if it is not found, it will prompt for a product key. The product key can be win 7, 8, or 10.
  9. BR-549
    Sep 22, 2013
    2,178
    419
  10. spinnaker
    Oct 29, 2009
    5,074
    1,176
    That doesn't make any sense. What if your hard drive is trashed after Windows 10 upgrade?
  11. spinnaker
    Oct 29, 2009
    5,074
    1,176
    That is basically the link I posted. I am trying it now. What I did was to upgrade to Windows 10 on my "old" hard drive. I created a DVD. I then disconnected the "old" drive and booted the DVD and started the install procedure. My theroy is that the product code is stored on line with the version of Windows 10 you are running. Install will check the product code and install the right version of Windows 10.. We will know soon if I am right.
  12. BR-549
    Sep 22, 2013
    2,178
    419
    I wouldn't try to install that way. I was just recommending a repair disk procedure. Win 10 can be finicky with it's upgrade steps, as I found out after calling ms.
    I saw your other post and asked some questions, maybe I can save you some time.
  13. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    Never used it for DVD, just cloning a HD. For later Windows ver. it has to be the original PC.
    Max.
  14. spinnaker
    Oct 29, 2009
    5,074
    1,176
    Install what way?? You should be able to install Windows 10 to a new drive.
    My first attempt failed. Some error about corrupted files. I tried reformatting the partition this time.
  15. BR-549
    Sep 22, 2013
    2,178
    419
    Does clone mean the same as mirror? I backup a mirror each day on an external drive.
    And if spinnaker can connect multiple drives, and has the room on the drives, He can easily mirror the win10 upgrade from his old drive. As suggested. We don't need speed, just some temporary drive space. He might have enough room on that new ssd.
  16. BR-549
    Sep 22, 2013
    2,178
    419
    You can install windows 10 on a new drive IF you have a NEW($119.00) windows 10 key, OR if you have previously did an UPGRADE, on you OLD operating system.
    MS told me today, there is no other way!
  17. spinnaker
    Oct 29, 2009
    5,074
    1,176
    They are wrong. I just did it. The second time was the charm. The link you provided / I provided works. You just create a boot disk.
    I am installing a 3rd time because I did not have my partitions laid out correctly for dual boot of Ubuntu.
  18. eetech00
    Jun 8, 2013
    679
    116
    What doesn't make sense? That's how that works.
    Maybe...what you really need to ask is how to make an image backup of an existing windows installation.
    Is that what you meant to ask?
  19. spinnaker
    Oct 29, 2009
    5,074
    1,176
    No that is not what I meant to ask. The first post was perfectly understandable. And I got it to work using the link I found in post #6.
    The problem is there is a whole lot of misinformation out there on reinstalling Windows 10.
  20. BR-549
    Sep 22, 2013
    2,178
    419
    I just found this on ms support, look at the date.
    Note
    Starting with the November update, Windows 10 (Version 1511) can be activated using some Windows 7, Windows 8, and Windows 8.1 product keys. For more info, see the section Activating Windows 10 (Version 1511 or higher) using a Windows 7, Windows 8, or Windows 8.1 product key in this topic.
    I just got 1511 yesterday.
    And that's far different from what they told me on the phone yesterday.
