I was thinking of another possibility for a circuit is there a stator with 7 poles?There should at a minimum be a decoupling capacitor across the '4017, but maybe more to the point, does VDD change much when you connect the coils?
Can you describe how you tested your coils? Was it perhaps by direct connection to a power supply?
Your circuit is the right idea and is exactly how I would do it, but the 4017 outputs need to be amplified with external transistors. A transistor array which contains multiple transistors in one package might be a handy option. See ULN2803 or ULN2003.
Two questions:
Is he really trying to power this with a 9 volt battery?
What is the resistance of the coils (he has a DVM)?
I'm lost. Where are we now? We need a schematic....I ended up changing the circuit I made ...
Once the current flow stops, the magnetic field collapses and the energy is gone. You don't really need to do anything except prevent the resulting inductive voltage spike from damaging other parts of the circuit. A reverse-biased diode is used for this...how do I get it to deplete its energy ...
right now i dont have a schematic but i am attempting to use the 555 timer circuit with a 4022 to produce the pulses but i think the coils are giving me i think emf feed back. this is the only pic i could find close enough to my work for now but i am not using this actual circuit let me explain:I'm lost. Where are we now? We need a schematic.
What do we know about these coils? The 4022 can only source or sink ~5mA, and that's barely enough to light an LED, let alone drive a coil.
I think you'll want the 4022 output to drive the gate of an N-type MOSFET. The source pin will be at ground, and the drain pin will sit below your coil. The MOSFET will control the return to ground for the power loop of your coil. You'll want a snubber diode across the poles of the coil, to absorb that inductive spike when the MOSFET turns off the energized coil.
I don't quite understand the input scheme you are describing. Is the lower diagram your own? Are you trying to count the times the "heavy load" is switched on?
If the TS used a fast enough clock; the pulses would be too short to saturate the inductor, and at the point of the pulse ending, a back emf would be produced.No. A copper coil is going to short the outputs of the 4017. When one output is trying to go HIGH, all the current will flow into all the other outputs which are sinking current. You are creating a dead short across the power supply through the outputs of the poor 4017.
The direction of diode?Add this to each coil. they will be very weak.
Backwards. Of course.The direction of diode?
Right, as described in #66, the 4022 won't be able to drive more than ~5mA into any one of those coils. But with the MOSFET solution, the coil will see the full 9V supply. Can your coil survive direct connection to the 9V supply, or will they require something to limit the current?
If the coil is a load then it could be draw more current, so the 9V cookies battery will not enough current to support, and you also need bjts or mosfets to drive the coils, try to calculate the total current of coils, maybe uln2003 can be used.I am working with a 9v battery as i have not bought a power supply unit.
A thread already reach to #76 and 4 pages long, but we still don't know the basic load, should we close this thread to avoid waste time for everybody?We still don't know anything about these "coils", right? DC resistance would be useful.
So you like Japanese baked eels ... slowly an slowly.Well, we just got a schematic in #67, so maybe we're getting started?
