Why does a copper coil stop circuit from working?
30,795
IIRC, the 4017 can be forced into, "dot" mode. One output fires at a time. To get them to sequence, you apply a ramp wave or a sawtooth wave at the input of the 4017 chip. It will go through selecting each output, one at a time, as the input voltage changes.
You are thinking of an LM3914 bar graph display.
Tony357
Joined Mar 24, 2015
37
Can you describe how you tested your coils? Was it perhaps by direct connection to a power supply?
Your circuit is the right idea and is exactly how I would do it, but the 4017 outputs need to be amplified with external transistors. A transistor array which contains multiple transistors in one package might be a handy option. See ULN2803 or ULN2003.
The way i tested the coil i connected it to my modified circuit with a darlington pair of bc108c transistors
wayneh
Joined Sep 9, 2010
17,498
Hmmm... Those are 200mA rated transistors, so it's still a mystery how much current was actually in the coil when you judged them to be adequate. Something other than the coil may have been limiting the current.
Without more details - power supply voltage, coil ohms or winding details, mA of current in your test - it's tough to offer much advice. Shooting in the dark.
alfacliff
Joined Dec 13, 2013
2,458
the 4017 counter has no buffeers on the outputs. one output with a low resistance load could stop the count. you need to have buffers (transistors probably) to handle the current of the coils and to isolate the outputs from the loads.
ScottWang
Joined Aug 23, 2012
7,398
He said that he used the darlington pair of bc108c transistors to drive the coils in #43.
DickCappels
Joined Aug 21, 2008
10,169
There should at a minimum be a decoupling capacitor across the '4017, but maybe more to the point, does VDD change much when you connect the coils?
SgtWookie
Joined Jul 17, 2007
22,230
There should be a 10k resistor between the 4017 output and the transistor base. Less than that may cause problems.
Also, you will need to have a diode in reverse bias across the coil to take care of the back EMF when the transistor turns off, or the transistor (and maybe the 4017 too) will be destroyed.
Tony357
Joined Mar 24, 2015
37
Hi what do you mean by reverse bias as i have one end of the coil coming from the 4017 through the darlington pair and into the coil and the other side is connected to the positive line is this done correct?
Tony357
Joined Mar 24, 2015
37
I will check and do my best as i am not with my circuit at present but from what i have seen the coil holds the current from the rest of the circuit.
SgtWookie
Joined Jul 17, 2007
22,230
Does it start cycling again if you disconnect the coil? If so, then your coil's resistance is too low for your power supply, and the 4017 is probably OK then.
Tony357
Joined Mar 24, 2015
37
Hi and thank you for your reply. And yes the circuit carries on once the coil is taken out.
( sorry for the long reply i'm babysitting)
