why do I get a different transfer function of Butterworth filter
Discussion in 'General Electronics Chat' started by xinyancode, Sep 22, 2015.
  1. xinyancode
    Sep 22, 2015
    Hi, everybody,
    I have deduced several times for the transfer function of 3rd order Butterworth low pass filter, but the transfer function I got is
    vo(s)/vi(s) = 1/( 2S^3 + 4S^2 + 4S + 2 )
    while the transfer function of this filter in textbook and many document is
    vo(s)/vi(s) = 1/( S^3 + 2S^2 + 2S + 1 )
    I don't know what the problem is in my deduction, can anyone help me?
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    V(out) = V(yours); V(b00k) is wrong.
    You can see that yours is more realistic. Think about what happens at low frequency; R1,R2 create a voltage divider of 1/2.
    xinyancode likes this.
  3. xinyancode
    Sep 22, 2015
    Hi, MikeML,
    thank you so much for your help, I come to understand more about this problem. and your simulation is great, I will also learn to use LTSpice, it seems very powerful.
    yet, I am still a little confused on why there is the gap between the two transfer function. Is it possible that other people consider the transfer function based on voltage source with the 1 ohm internal resister, while I only consider the ideal voltage source.
    thank you again......
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    Not likely:
