electrolytic caps used to be more reliable, the US brands were copied by the japanese, who were copied by the koreans, who were copied by the chinese. each copy got a little more on the cheaper side, till they dont last very long now.
also, electrolytics fail because of the worng voltage on them. I have replaced caps with only 1.5 volts across them where the cap was rated at 50 volts. the electro chemical process in the caps needs the proper voltage to keep working. older caps were marked in WVDC, or working volts dc, the voltage they were designed to work at. you dont see that much any more. using a cap at way below its voltage rating causes it to decrease in capacitance over time.
