why am I getting "x" in the denominator?
Discussion in 'Math' started by PG1995, Nov 14, 2011.
  1. PG1995
    Thread Starter Active Member
    Apr 15, 2011
    753
    5
    Hi
    I was solving an example problem using a different method using a formula linked below. The answer I ended up has an "x" in the denominator which isn't there in solution the book presents. I've failed to figure out where I made a mistake. Could you please help me? Thanks a lot.
    Book's solution: http://img810.imageshack.us/img810/8342/examplek.jpg
    My Solution: http://img717.imageshack.us/img717/2970/img0003wu.jpg
    Formula used: http://img411.imageshack.us/img411/8596/exactequation.jpg
    With best regards
    PG
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    You went astray in some of the integration process and algebraic manipulations - you need to watch which integration variable is being applied at each step.
    M=e^{2y}-ycos(xy)
    N=2xe^{2y}-xcos(xy)+2y
    \int{M}\partial x=\int{(e^{2y}-ycos(xy))}\partial x=xe^{2y}-sin(xy)
    c=\int{M}\partial x+\int {\[ N-\frac{\partial}{\partial y} \int M \partial x \] }\partial y \\ =\int{M}\partial x+\int {\[ (2xe^{2y}-xcos(xy)+2y)}-\frac{\partial}{\partial y}(xe^{2y}-sin(xy)) \] \partial y \\ =\int{M}\partial x+\int {\[ (2xe^{2y}-xcos(xy)+2y)}-(2xe^{2y}-xcos(xy))\] \partial y \\ =\int{M}\partial x+ \int{2y} \partial y \\ = \int{M}\partial x+y^2 \\ =xe^{2y}-sin(xy)+y^2
    Hence
    xe^{2y}-sin(xy)+y^2=c
    or given c is a constant, we may write without loss of generality
    xe^{2y}-sin(xy)+y^2 + c=0
    to agree with the book solution
    PG1995 likes this.
  3. PG1995
    Apr 15, 2011
    753
    5
    Thanks a lot, t_n_k. It was really helpful
    Best regards
    PG
