Your driver transistor (the 2N3906) drives the output transistors.
The output transistors drive the speaker.
1) What is the maximum peak current of the output transistors into the speaker?
2) What is the minimum peak input current to the output transistors? That is the maximum output current of the driver transistor.
3) What is the minimum peak input current to the driver transistor? That is the maximum output current from the differtential amplifier.
Then use Ohm's law to calculate resistor values.
Simple!
Simple!
