Why a Buffer stage in between amplifier and LPF?
Discussion in 'General Electronics Chat' started by manjuarun, Apr 19, 2010.
  1. manjuarun
    Mar 8, 2010
    25
    What is the use of a buffer stage between an amplifier stage and an LPF stage? My understanding was that its for impedance matching.Or is it for holding the signal for more processing time from amplifier to LPF stage? Is the buffer is same as buffer amplifier, or they are two different circuits? If it is a buffer amplifier how do we choose the gain? Can any body of you please clear my doubts?
    Many Thanks
    Manju
  2. kingdano
    Member
    Apr 14, 2010
    377
    19
    Do you have a specific circuit in mind? Or are these general design questions?
  3. manjuarun
    Mar 8, 2010
    25
    I want to design a simple signal processing circuit consists of an amplifier and a filter circuit.I got a review comment like just add one buffer between this. But I dont really know that why it is needed? or what will it do with my signal processing.I would like to get a clear understanding of buffer and its purpose,then only I can decide that whether a buffer should be included in my ckt or not.
    Manju
  4. t06afre
    May 11, 2009
    5,939
    1,222
    you should post your schematics
  5. rjenkins
    Nov 6, 2005
    1,015
    69
    A buffer is, generically, a low or zero gain amplifier for impedance conversion or simply to isolate the previous stage from any loading effects of the next stage.
    As t06afre says, you need to supply more info to get a better reply.
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Zero gain would mean zero signal transmission - gain should be greater than zero.
  7. rjenkins
    Nov 6, 2005
    1,015
    69
    Terminology - zero gain as in zero increase of signal level.
  8. t06afre
    May 11, 2009
    5,939
    1,222
    Then we talk about gain we often use dB. And a gain of zero dB is equal to a gain of one. So zero gain is more an expression or figure of speech there the dB has been left out
  9. manjuarun
    Mar 8, 2010
    25
    Thanks rjenkins..
    If buffer is a zero gain amplifier, does it have inverting and non inverting type like normal opamp amplifiers? does it have differential type? How do we ensure the empedance matching?
    Manju
  10. rjenkins
    Nov 6, 2005
    1,015
    69
    That's all down to the overall circuit and frequencies involved, which you have not yet provided info on.
    For something like a low frequency sensor signal, it could be an opamp.
    For an RF stage, it would likely be a transistor.
    For matching within a circuit, it's often enough to know that the output impedance of one stage is lower than the input impedance of the next, but again details of the application are required.
  11. manjuarun
    Mar 8, 2010
    25
    for giving a schematic diagram , its not yet ready. Its only in my mind. But I can give you the details. A differential amplifier with a gain factor of 10 and a Low pass filter.The cut off frequency is 50 Hz. To isolate the amplifier stage from the LPF I can use a buffer right? And also for impedance matching. The LPF, I would like to take is of butterworth type which has flat pass band response(It is the rough idea, need to think on this).
    Ok..Now would u pls give me suggestions ?Can I use an opamp type buffer for my application? What are the other factors I need to study before going for a design?
    Manju
  12. manjuarun
    Mar 8, 2010
    25
    Please do bear with me If I'm asking irrelevent question.I am just a beginner on this.
    Ok..I will reframe my doubt like this
    A buffer is used to transfer a voltage from a first circuit, having a high output impedance level, to a second circuit with a low input impedance level. For my application first circuit is an opamp based differential amplifier which has high input impedance and low output impedance. The second stage is an opamp based butterworth low pass filter which also has high input impedance and low output impedance. Then how do a buffer will server here?
    Manju
  13. rjenkins
    Nov 6, 2005
    1,015
    69
    From what you describe, it does not sound like a buffer should be needed.
  14. t06afre
    May 11, 2009
    5,939
    1,222
    I agree with Robert. But if your teacher advice you to put in a buffer just do it. No point in agruing to much with your teacher ;). It will not do any bad in your circuit, and it is not wrong to put it in. But from the information you have given, not needed.
    Here is a link to a good ebook http://focus.ti.com/lit/an/slod006b/slod006b.pdf See section A.3.17 Buffer ​
  15. Darren Holdstock
    Feb 10, 2009
    262
    11
    I agree with the other respondents, if the differential amp is constructed around an op-amp then the output impedance should be low enough not to need buffering when driving an active filter input. However, if it's a 2 transistor differential amplifier circuit (AKA long-tailed pair) then a buffer might be necessary.
    The input impedance of an active filter can be complex (depending on architecture), and when plotted against frequency can have the same shape as the transfer function characteristic. I've made sneaky use of this for equalisers based on the old 1970s Williamson graphic EQ circuit - where the original had passive LRC networks, I used the inputs of gyrator and Sallen and Key circuits (like Figure 5 here). Works a treat if it's done right.
  16. kingdano
    Member
    Apr 14, 2010
    377
    19
    Is that your design on the website?
  17. chetan mehra
    Aug 18, 2010
    See there is a main difference between buffer gate and buffer.a buffer gate is used to enhance the weak signals because every gate is a signal amplifier,in this configuration two not gates are connected in series so that the current sinking or sourcing capabilities of the resulting gate would increase.
    whereas the buffer circuit is used to isolate one circuit to another,it means the changes which occurs in one circuit will not affect the other.(it may be made up of transistors or may not be.)
