whistle key finder project (or audio response) 2
Discussion in 'The Projects Forum' started by den421, Sep 29, 2011.
  1. den421
    Sep 29, 2011
    with out mic how to get input for buzzer ?
  2. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I believe BZ1 doubles as the mic.
    What exactly IS BZ1, though, mozikluv?
    I once built a circuit similar to that one that used a piezo transducer, but that required an input frequency of 40kHz, which is far higher than your average whistle. Someone didn't know what they were doing when they designed the circuit I tried....
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    It is not a buzzer. A piezo buzzer (actually it is a beeper) has an oscillator inside. this project uses a piezo transducer.
    A similar circuit is at Red Circuits: http://www.redcircuits.com/Page29.htm except it uses a real microphone.
    The similar circuit was also at Electronics Lab (but not anymore) where I helped a student get it to work. It worked very poorly because the piezo transducer was not loud enough so we constructed a push-pull Cmos driver to double its driving signal level.
    I think this project will also have the beep not loud enough. The piezo transducer is most sensitive to 5kHz but nobody can whistle that high so it might not hear a whistle.
    My daughter bought a cheap Chinese Keys finder. It beeped whenever she talked and when the TV was turned on. I couldn't fix it because all of its circuit was inside a black blob.
  5. chino00007
    Nov 16, 2011
    19
    Thanks Audioguru,
    You help a lot with this Circuit! i was looking for something like this! thanks!
