Which way to connect a capacitor? - really basic question.
Discussion in 'General Electronics Chat' started by AgeingHippy, Dec 4, 2010.
  1. AgeingHippy
    Nov 28, 2010
    16
    Hello All
    I need to connect a number of decoupling capacitors and am confused about which way to connect. My web search has turned up a lot of warnings but nothing to clarify to a complete noob.
    The negative (shorter) leg (cathode) on the capacitor. Does that connect to the GND or to the 5v / 12v side?
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    Did you read this thread with the attached documents:
    http://forum.allaboutcircuits.com/showthread.php?t=45583
    Small ceramic capacitors do not have a polarity, so they can be mounten either way.
    Electrolitc capacitors have markings for the minus (- connection) most times there is a coloured band on that side.
    You should take care that the polarity of the electrolitic capacitors is correct, otherwise you can damage the capacitor (sometimes even with a loud bang).
    For more information on the capacitors itself take a look at the capsite:
    http://my.execpc.com/~endlr/index.html
    Bertus
  3. AgeingHippy
    Nov 28, 2010
    16
    I have Bertus, but it still does not answer my most basic question. Is the cathode (marked negative on the capacitor) connected on the ground side or the V++ side?
    I know the polarity has to be correct. Everyone and every web page states this, but does not say which way round is the correct polarity!!
    Can anyone simply answer the question please?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    One important difference in polar capacitors is that electrolytic caps have the negative terminal marked, and tantalum caps mark the positive. Always be sure of the relative voltage differences of points with a capacitor between them so the smoke stays in the device.
    Old paper and foil caps had a mark at one end to indicate which lead attached to the outer wrap of foil. That was so you could tie that lead to ground and help suppress radiation of noise.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Positive goes to positive, negative to negative.
  6. AgeingHippy
    Nov 28, 2010
    16
    Hi Beenthere
    So to summarise in terms of my question - the cathode (negative marked leg) goes to Ground and the Anode possibly marked positive) goes to the 12v or 5v side?
    I know whomever first decided that electrical charge was a fluid decided it flowed one way but it (the electrons) actually flow the other way. This continually confuses me.
    Sorry guys. I know I am being really thick here, but I need this spelled out for me.
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    An electrolitic capacitor does have a + and a - connection.
    They are NOT called cathode and anode, as they do with diodes.
    The + connection goes to the point with the highest potential (VCC or +V)
    The - connection goes to the lower potential (GND)
    At an opamp you can have a negative powersupply.
    In that case the + goes to the higher potentioal (GND) and
    the - goes to the lower potential (VEE or -V).
    Bertus
  8. AgeingHippy
    Nov 28, 2010
    16
    Nice one
    Thanks bertus.
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
