Which voltage to use when calculating Current
Discussion in 'Homework Help' started by pprendeville, Jan 13, 2010.
  1. pprendeville
    Nov 19, 2009
    15
    Hi all,
    Just want to find out which voltage I should use when calculating the current through the 5 ohm resistor in the pic. Originally I thought it was the supply voltage, 20V but according to the notes it says to use the voltage drop across the resistor, i.e. 9.1V.
    Why is this so?
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Well
    V=I*R;
    I=20V / (5Ω+ 12|Ω|18Ω||9Ω+4Ω||4Ω)=20V/11Ω=1.81A
    So voltage on 5 ohm resistor is equal
    V=1.81A*5Ω=9.09V
  3. mrmount
    Dec 5, 2007
    59
    7
    That is because the supply voltage 20 V is across the total resistor combination and not 5 ohm resistor alone. See Jony130's calculation.
  4. pprendeville
    Nov 19, 2009
    15
    cheers lads.
