Which voltage is the LDPR chip making (MacbookPro)
Discussion in 'General Electronics Chat' started by ReneS, Feb 15, 2012.
  1. ReneS
    Feb 14, 2012
    5
    I am still repairing a Macbook pro.
    Since 2 resistors are broken, i can not determine the voltage that is comming out of the LDPR converter.
    http://www.mijnalbum.nl/Foto-S4ZFNXLQ.jpg
    If somebody nows this voltage I can calculate the resistor values.
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    Better pictures needed.
    I too repair macbooks.
    Infact I have a Macbook pro and an ibook G4 in service bench.
    May be I can locate the value but I need more info
  3. ReneS
    Feb 14, 2012
    5
  4. R!f@@
    Apr 2, 2009
    8,785
    771
    Okay..I gtg now.. will check later tonight.
  5. ReneS
    Feb 14, 2012
    5
    Thanks.
    While your checking, could you also check the resistance between pin 2 and pin 5 of the chip.
    This is the resistance between the output of the converter in relation to GND.
    This is only 5 ohms on my board.!!!
    Thats to low in my opinion......
