which type of camera are good
Discussion in 'The Projects Forum' started by ep.hobbyiest, Oct 13, 2014.
  1. ep.hobbyiest
    Aug 26, 2014
    94
    i need camera for my project. i m confuse in which type of camera i should use.
    i read the specification for CMOS and CCD type of camera.
    Every have some advantage and disadvantage. So which one is good can give good picture quality .
  2. djsfantasi
    Apr 11, 2010
    2,911
    881
    What is "good"?
    No, I am not being rude. You need to define what specifications you need. Then you can answer my question. All the specifications are not meaningful, unless you can define what you are looking for.
  3. wmodavis
    Oct 23, 2010
    737
    150
    It is your project so tell us what the project is and what are you trying to achieve and what is your criteria for success. We can only guess and unless you help with more information there will likely be little practical help forthcoming.
  4. wayneh
    Sep 9, 2010
    12,402
    3,249
    Either technology can offer a great image. "Good" depends on other factors. Size, cost, power, durability, access, supporting circuitry, and on and on. Only you can define what "good" is.
    Why do you even care about the underlying technology, as opposed to the final result?
  5. Sensacell
    Jun 19, 2012
    1,184
    277
    The output format is the place to start- what type of imaging are you doing? still? video? NTSC? VGA? MIPI?
