Which pin is pin 1
Discussion in 'General Electronics Chat' started by nerdegutta, Jan 25, 2013.
  1. nerdegutta
    Thread Starter Moderator
    Dec 15, 2009
    2,565
    805
    Hi.
    I got some of these, and I am not sure which of the pins that are pin one/I can't see the marker. Anyone?
  2. GopherT
    Nov 23, 2012
    6,297
    4,019
    Noice that the left top edge is bevelled and the right edge is 90-degrees. Now look at page 4 of the datasheet and you will see the extra line on the side that is bevelled to show that pin 1 is the top left in your photo. (PIN #1 IS NEAR THE RED "A" on your photo).
    nerdegutta likes this.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    I will also say that A is pin 1 here
  4. mcgyvr
    Oct 15, 2009
    4,784
    973
    really no question when you read the datasheet :p
  5. nerdegutta
    Dec 15, 2009
    2,565
    805
    Thanks guys. I understand now.
    Um.... Feeling a bit guilty about asking stupid questions here now, as I can clearly see it in the datasheet. If I only had paid attention to what I read.... :rolleyes:
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    Sometimes they aren't exactly clear on datasheet drawings what a line means (bevel, step, etc).
    It's an easy mistake, especially when you've read the datasheet a lot for using the other package types, one tends to skim over stuff they've looked at a lot.
  7. nerdegutta
    Dec 15, 2009
    2,565
    805
    Yes, I tend to get blind, starring at the illustrations.
  8. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    Here is the pin-out picture from the datasheet:
    I marked the slanted side.
    Bertus
  9. nerdegutta
    Dec 15, 2009
    2,565
    805
    I got it working last night. Just had to double check before I soldered it in place.
    Thanks.
