which parts are which in the circuit
Discussion in 'General Electronics Chat' started by lokeycmos, Oct 15, 2011.
  1. lokeycmos
    Thread Starter Active Member
    Apr 3, 2009
    432
    7
    in the pic i have a line filter with its own schematic on it. it also has the values. can someone please tell me which values go with which part? i want to multisim this and look at scope views to see how the low pass works. TY
  2. VoodooMojo
    Nov 28, 2009
    503
    53
  3. lokeycmos
    Apr 3, 2009
    432
    7
    cool, how did you draw that up so nice? what are circles with arrows on both ends for?
  4. VoodooMojo
    Nov 28, 2009
    503
    53
    I gleaned it from other images from different datasheets
    circles and arrows display resonance set up by the phase winding and the neutral winding with the capacitors
  5. KMoffett
    Dec 19, 2007
    2,584
    234
    Ah! A fellow AXMAN shopper. ;)
    Ken
    VoodooMojo likes this.
  6. MrChips
    Oct 2, 2009
    12,636
    3,454
    Yeah. I was going to post the spec sheet but Mojo's drawing posted two minutes before me was just too nice.
  7. praondevou
    Jul 9, 2011
    2,936
    489
    I would think that the circle with arrows indicates that this is a common mode choke coil. The arrows pointing in the same direction would indicate that this is a coupled inductor (although it isn't drawn as one) where the windings start both at the same end, hence suppressing CMN together with the Y-capacitors. Not sure if you will be able to simulate it in Multisim.
    Have a look at the attachment.
  8. MrChips
    Oct 2, 2009
    12,636
    3,454
    Welcome back praondevou! We missed you.
