which op amp?
Discussion in 'The Projects Forum' started by Gadersd, May 26, 2013.
  1. Gadersd
    Dec 8, 2012
    98
    I made a am transmitter. The signal is very weak because of the low voltage so I need an op amp to amplify it. I am not sure which op amp has the speed for my 1 MHz transmitter. Which op amp would be fast enough to handle 1 MHz and amplify the signal up to 12 volts.
  2. Dodgydave
    Jun 22, 2012
    5,171
    778
    Non, you need to use a powerful transistor output to boost the signal, can you post your circuit ?
  3. Gadersd
    Dec 8, 2012
    98
    My schematic is the same except that the input to the oscillator is 5v.
  4. richard.cs
    Member
    Mar 3, 2012
    162
    31
    Can you give us more details about the oscillator please. A part number or a datasheet would be good.
  5. Gadersd
    Dec 8, 2012
    98
    The part number is 27861. I bought it from jameco.
  6. Dodgydave
    Jun 22, 2012
    5,171
    778
    You have already got a thread going about this which was answered by Ron H, the maximum supply is 5Volts !!
    thread
  7. wayneh
    Sep 9, 2010
    12,405
    3,256
    +1
    That oscillator is meant to run TTL (small) loads. I played around a bit with one to get the most signal out of it but as you may know, 20 feet or so is about all you'll get with a reasonable length of antenna (less than 10').
    It produces a square wave, which is a mix of many frequencies. I didn't see much spread to other frequencies when I built this but amplifying a square wave will likely put you in violation of local laws regarding radio broadcasting. It's likely to interfere with your neighbors AM radio reception.
  8. richard.cs
    Member
    Mar 3, 2012
    162
    31
    Well, if you actually look at one on a scope it's usually a clipped sine. You do get high frequency content from the clipping but it's not as bad as a square wave. They are usually 1-transistor oscillators diode-clamped to the supply rails and work over a reasonable range of supply voltage. With a suitable band-pass filter on the output I would happily modulate one in the way suggested, but not push it to 9V.
    I would be inclined to reduce the supply to 5V (although I suppose if it's survived this long at 9V it's probably fine), clamp the 8-ohm side of the transformer with antiparallel diodes (maybe LEDs, could then modulate the supply in the range 3-7V which seems sensible). Then feed a 1 MHz LC filter and a 1-transistor amplifier with a tuned collector load running off 12V or so.
    Edit: Had a play in LTSpice, see attached.
    I changed the audio transformer to 1:1 (1000:8 ohms is about 11:1 in voltage) and dropped the oscillator supply to get more modulation with a sensible audio source. 40 mW output with second harmonic 35 dB down.
  9. wayneh
    Sep 9, 2010
    12,405
    3,256
    I don't think it's that bad. I mean the rise/fall time is less than 2% of the pulse width - less than 10ns out a 0.5µs pulse at 1 MHz - so it ought to look awfully like a square wave.
    You can measure the actual current draw from the device you have, and then you can get much more amplitude modulation of its power supply voltage by careful choice of the transformer in series with the power.
    In the project I linked earlier, I used capacitive coupling instead of the transformer and had good results in getting as much signal as possible.
  10. richard.cs
    Member
    Mar 3, 2012
    162
    31
    I'll confess I didn't really look at the specifications of that oscillator, it seems a lot closer to square than the ones I've used in the past. On those the datasheet gave a fairly wide window and actually measuring them they were about the middle 50% of a sine - I'll see if I can dig out a part number.
  11. wayneh
    Sep 9, 2010
    12,405
    3,256
    It may depend heavily on the loading? But I would think the users of these things would demand a pretty square clock signal from them.
  12. richard.cs
    Member
    Mar 3, 2012
    162
    31
    It may. I have to say I was very suprised when I discovered how far from square the ones I had were. On the other hand so long as it's monotonic and consistant between cycles it probably doesn't matter.
  13. RamaD
    Dec 4, 2009
    254
    33
    I have no knowledge on this area. I was wondering whether something like this can be used? It is quite expensive though.
    http://www.linear.com/product/LT1210
  14. richard.cs
    Member
    Mar 3, 2012
    162
    31
    I have had sucess misusing CATV amplifier modules similar to this one: www.nxp.com/documents/data_sheet/BGY887B.pdf‎
    None of them are specified down to a megahertz but they'll probably work fine. You can get about 15 V pk-pk from them before they start to distort too much. They're about £30 each from Digikey.
  15. wayneh
    Sep 9, 2010
    12,405
    3,256
    We're two pages in and you still haven't said what you really want to do. What sort of range do you want? Are you aware that you will likely be breaking local laws if you continue?
    A single transistor RF amplifier is all you need to take you into a range that is likely not legal. As is, the crystal with a long antenna has a range of maybe 20 feet or so and is probably fine. Of course range depends a little on the receiver as well.
