Years ago, read an article about when the state of California standardized the line frequency. There was a statewide program to modify electric clocks to work at the new frequency. Not just the state-owned clocks, but all clocks!Sounds like the early days in power generation & distribution boasted a veritable frequency zoo.
Og God...You are so funny...So you want us to supply your homework answer. It doesn't work that way. You need to do some research on you own and then ask questions about that, if you still have some.
50HZ would work for me. I like to be fashionably late.60Hz is better because all my clocks would not keep proper time.
Yep. It's a real hoot when someone is expected to put in some effort on their own. What a riot! They should make a sitcom based on it.Og God...You are so funny...
And thanks to all for helpful Answers..
Once again thank a lot.
Come again .....the main difference is that the transformers and motors are heavier in 50 hz systems, more iron needed. thats one reason aircraft went to 400 hz, much lighter transformers and motors on 400 hz. iron core losses lower.
Please provide some decent references to back up this claim.your body has some natural "oscillations" around 60 hz, which is one of the reasons they decided to go with that frequency for safety.
by Jake Hertz
by Jake Hertz
by Aaron Carman
