Yes, I made a mistake and I messed up something.. It's just seemed to me both are about equivalent processors.Did you compare the parameters, or did you just pick two random devices out of your a.. nose an chucked them here? What are the parameters of the input singnals? How fast do you need to react?
The msp has only 128 bytes of ram and runs at 16MIPS, while the dspic has 8K of ram and runs at 30MIPS. Guess which one is better?
Also note that 128B of ram will likely be nowhere near enough to run any kind of filtering.
