Which language to start with
Discussion in 'Embedded Systems and Microcontrollers' started by Angello90, Apr 5, 2010.
  1. Angello90
    Apr 5, 2010
    Hi guys,
    I'm just staring with pic, and I am wondering which language to pick as the first one, Basic, Assembly or C? I already know C, but I'm not sure if this is a good starting language.
    Cheers
  2. Tahmid
    Jul 2, 2008
    344
    27
    I use both PIC and AVR and I know BASIC and C (better at BASIC). I found (my opinion) that I like the BASIC structure and programming very good and efficient and so I use mikroBASIC. I recommend you take a look at it as it also has a free version.
    But since you already know C, you should be looking to improve on that, I think. So check out mikroC or CCS or Hi-Tech, whichever you prefer (my choice is mikroC).
    The mikroC and mikroBASIC compilers have very good prebuilt library functions, which are a great help.
    Take a look at:
    www.mikroe.com
    Hope this helps.
    Tahmid.
  3. rjenkins
    Nov 6, 2005
    1,015
    69
    Each make of compiler has it's own none-standard extensions to handle the built in peripherals. It's as much picking a compiler you get on with as what language you use - two different C compilers may work in completely different ways.
    Personally, I use part assembly and part C, using the CCS compiler as that seems to have very good peripheral support and libraries.
