Which is the best amplifier : rate and comment
Discussion in 'The Projects Forum' started by simeonz11, Jan 9, 2010.
  1. simeonz11
    Thread Starter Active Member
    Apr 29, 2008
    98
    poo poo poo
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Not enough information. What is the frequency of the sine wave? What kind of load will it drive?
  3. t06afre
    May 11, 2009
    5,939
    1,222
    I think should go for an dedicated audio poweramp IC. How many watt do you need?
  4. simeonz11
    Apr 29, 2008
    98
    Lol sorry for that obvious mistake , forgot to mention .
    it will drive a 1:1 isolation transformer in the full audio ranges 300hz to 20000hz , so an inductive and resistive load .
    A maximum of 5 amps .
    Yes I do expect alot of heat and am prepared with big heatsinks , so about 100 watts .
  5. t06afre
    May 11, 2009
    5,939
    1,222
    You say max 5 A, are you sure you will be able to to create such a current with +/- 30 volt? Do you have some inforation about your transformer.
  6. simeonz11
    Apr 29, 2008
    98
    Unfortunately ,I still do not .
    Probably a heavy duty 1:1 audio transformer that fits this frequency range , still looking around .
    The components are just there as an example besides the op amp.
  7. t06afre
    May 11, 2009
    5,939
    1,222
    I see some problem here. First of all I think it would be best to find the transformer first. Then base your design around this transformer. Now it is to many loose ends. You may end up with a useless design.
  8. simeonz11
    Apr 29, 2008
    98
    What would those problems be so I can better inform myself ?
    I am still undecided , most are expensive . I expect 5 amps with an inductive and resistive load with one of those center tapped heavy duty transformers.
    My transistor gains and op amp rating looks good enough tho , the transistor pair I will choose have a gain of 50-70 rated for 15 amps
  9. t06afre
    May 11, 2009
    5,939
    1,222
    The problem is the transformer. You have a quite wide frequency range. So you might experience a phenomenon named transformer core saturation http://www.opamp-electronics.com/tutorials/ac_theory_ch_009.htm
    On the bright there are is many small firms that have specialized in making custom transformers. You should call such a firm give them your specification. They will be able to advice you. Do this before you put to much effort into your project
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    The output transistors must have typical gain or more or they will not be able to drive an output of 5A when driven from the max 200mA output of the opamp.
    The single diode operates the output transistors in pure class-B which produces pretty bad crossover distortion.
    Audio amplifiers operate in class-AB with two diodes or a Vbe multiplier transistor and the output transistors have emitter resistors. The output transistors conduct a small current all the time.
    The opamp is fast so it will try to reduce the crossover distortion especially the voltage-follower where all the gain of the opamp is used as negative feedback to almost eliminate the crossover distortion.
  11. simeonz11
    Apr 29, 2008
    98
    Hi Audioguru , thx for commenting .
    So whats stopping me from just using a voltage follower with nothing but the 2 transistors and some feedback .
    I heard it doesnt do so good and I also heard it eliminates distortion . So whats true ?
    It sure would be the simplest and most efficient solution if it did work , whats your opinion ?
  12. Audioguru
    Dec 20, 2007
    9,411
    896
    Why don't you use a class-AB audio amplifier IC that is designed to produce extremely low distortion?
    This simple class-B circuit has crossover distortion.
  13. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Why don't you just get something like a cheap pair of TDA7254 audio amps (about $5/ea), feed one a noninverted signal, feed the other an inverted signal, and connect the outputs to the primary of your transformer? It won't need to be center tapped that way.
    Avnet Express has them for under $3:
    http://avnetexpress.avnet.com/store...=500201&langId=-1&storeId=500201&listIndex=-1
    Mouser has them for about $4.50 or so.
    Digikey sells them for around $5.80.
    You'll probably wind up needing a broadband toroidal transformer; a fairly large one. Saturation at the lower end of the frequency range will be a problem.
  14. simeonz11
    Apr 29, 2008
    98
    Can this be used @ +-24 volts ?
    Can this drive 200mA , that is my absolute minimum ?
    I need something simple and cheap , 5 dollars is too much , I need 6 of these 200 mA amps
  15. simeonz11
    Apr 29, 2008
    98
    Looks like an efficient compromise
  16. Audioguru
    Dec 20, 2007
    9,411
    896
    Crossover distortion is at high audio frequencies. Opamps have extremely high gain at very low frequencies but not much gain at high audio frequencies so the negative feedback reduces but does not eliminate crossover distortion.
    It is not difficault to properly bias the output transistors in class-AB so there is no cossover distortion.
